Forced Induction Turbos/Superchargers
Turbo help again
Old Oct 19, 2009 | 09:16 AM
bcss/sc's Avatar
Turbo help again
So I've been working on my turbo swap for about a month in half and yesterday I started it up with out the down pipe and with stock injectors and boost controller set low and it blew alot of smoke and wouldnt hold an idle. Is this normal for a car with out a tune? And what about the smoke I'm guessing the smoke is from being a brand new turbo with a little bit of oil in it still?
Old Oct 19, 2009 | 12:02 PM
ShortStack's Avatar
The injectors werent changed?
Old Oct 19, 2009 | 01:03 PM
bcss/sc's Avatar
Yah I haven't changed them out yet could that be the idle problem?
Old Oct 20, 2009 | 12:03 PM
ShortStack's Avatar
Im trying to figure this out here..
Have you changed the tune at all?
Old Oct 20, 2009 | 04:04 PM
bcss/sc's Avatar
No tune yet i'm guess that's why the idle is jumping around and Im putting the 60 injectors on and welding the down pipe on but it was blowing smoke really bad and would only run for a min then die
Old Oct 20, 2009 | 04:22 PM
hungryhip-ccp's Avatar
what color is the smoke? did you use a restrictor in the feed line? is it bb?
come on you gotta give us way more info, thats why no one has offered much help
did you change the maf location?
it should idle fine, if the tune /inj are stock unless you have a vac leak or moved the maf
Last edited by hungryhip-ccp; Oct 20, 2009 at 04:22 PM. Reason: Automerged Doublepost
Old Oct 20, 2009 | 08:29 PM
bcss/sc's Avatar
Thumbs down
The smoke is blue ish colour and Restritor?I'm trying my best with this it's my first build.I left the maf in the same spot as it would be on the cold air intake.I haven't put the down pipe on yet or the 60s so I'll get the 60s on check over everything again and try it again
Old Oct 20, 2009 | 08:31 PM
ShortStack's Avatar
if you have blueish smoke that means that oil is being burned.. not good... check your head gasket.
Also, you need to place a restrictor in your oil feed to not over flood the turbo with oil.
Old Oct 20, 2009 | 11:35 PM
bcss/sc's Avatar
Like I said when I got the turbo it was oily so could that maybe be it?and I don't understand how it could be the head gasket the car has been parked for almost 2 months and wasn't blowing smoke before all of this. What's the best way of checking taking the plugs out and check to see if that's what's going on? Or remvibg the head?
Old Oct 21, 2009 | 01:45 PM
its oil leaking past the seals in the turbo, you need a restrictor in the feed line to restrict the flow of oil to the turbo.
Old Oct 21, 2009 | 08:15 PM
damien's Avatar
You guys have too much patience for something like this.
Supercharged06SS
Dec 11, 2022 04:47 PM
hacadacalopolis
Oct 28, 2015 06:09 PM
patooyee
Oct 15, 2015 05:11 PM
maliki778
Oct 1, 2015 07:39 PM
