Forced Induction Turbos/Superchargers
Turbo Selection.
Old Feb 11, 2009 | 04:28 PM
SSdan's Avatar
Turbo Selection.
What do you guys think of this turbo? Garret T3 50 trim with a .63 A/R turbine housing? Looking for high 3's on pump gas.
Old Feb 11, 2009 | 09:01 PM
mike25's Avatar
should get you there easily...but i dont think your bottom end will be too great with that...its going to be more of an upper powerband turbo i would think.
Old Feb 11, 2009 | 09:25 PM
Maxim_X's Avatar
If it is a straight t3 forget about it. You might get high 2s. If it's a t4 hybrid it would be pretty much what I'm using. My plans are for mid 3's with it.
Old Feb 11, 2009 | 09:26 PM
widowedeight's Avatar
50 trim should easily get you into 3's i don't know how high tho...
Old Feb 12, 2009 | 09:33 AM
SSdan's Avatar
Maxim, what's the specs of your turbo? I'd imagine you'd be in the 3's easily with a 50 trim.
My bottom end will be getting an overhaul next month.
Also looking to push about 20-21psi or so.
Old Feb 12, 2009 | 09:49 AM
mike25's Avatar
if hes still got it he has the same turbo i had. it was a t3/t4 50 trim with a .63exhaust(maybe cant rem for sure) and i forget what the other side s.
Old Feb 12, 2009 | 10:23 AM
SSdan's Avatar
How was your spool time, decent? I hope to have full boost by 4500 at the latest. If not I'll get a 3071 instead.
Old Feb 12, 2009 | 12:11 PM
footb142's Avatar
pericision 6262 ball bearing thats wat im going with
Old Feb 12, 2009 | 01:04 PM
SSdan's Avatar
Probably going to lag like a ************. One of my biggest issues is good power with good spool.
Old Feb 12, 2009 | 02:36 PM
footb142's Avatar
for the size turbo is spools pretty quick
Old Feb 12, 2009 | 05:06 PM
Maxim_X's Avatar
I'm redoing my setup so I can get dyno numbers when done. But, yes, I plan to be in the mid 3's. Mine is an ITS t3/t4 50 trim .48 ar hot side. It will spool full under 3k in 5th gear.
But, the compressor is a t4's compressor because it's a hybrid turbo. That's why I can make that power. If I had a strait t3 50 trim it is a much smaller turbo and it wouldn't make that kind of power. I don't know weather or not you are looking at a hybrid or a strait t3.
Old Feb 12, 2009 | 05:53 PM
mike25's Avatar
i have a bit more displacement, but i believe 2500-3000 was full spool
Old Feb 12, 2009 | 07:52 PM
SSdan's Avatar
At first I was looking at a straight T3. My friend thought the whole time it was a T3/T4 50 trim. When he found out it was a T3 he's like no way those suck haha.
Now i'll be looking at a T3/T4 50 trim, possible slightly bigger A/R than yours. I'm shooting for a solid 390whp or so. Looks like a good choice, especially with the spool time.
Old Feb 12, 2009 | 07:57 PM
mike25's Avatar
if you know where to pick them up you can get them for 600-650. i want to say mine was .63/.60 or soemthing like that
Old Feb 12, 2009 | 08:00 PM
SSdan's Avatar
Was your full spool based on 5th gear readings too? I know for proper spool time you need a better gear, like 3rd or so.
Old Feb 12, 2009 | 08:06 PM
mike25's Avatar
yea mine were lower gears. i forget if it was 2nd or 3rd..one of the two...really shouldnt make alot of difference
Old Feb 12, 2009 | 08:09 PM
Ryan@zzp's Avatar
I don't know what your bugget is but if you are looking for the best in 50trims run the S256, with the .55 a/r that we offer. You get most of your spool from the size of the exhaust A/R and you keep your max flow up and turbine backpressures low by running a bigger exhaust wheel,this is how the S256 is setup. The extended tip flows around 5-6lbs/min more than your standard 50trims. You can make 400whp on pump gas with this turbo easily. The turbine housing is also S.S. the garret or PTE housings are not.
Old Feb 12, 2009 | 08:24 PM
SSdan's Avatar
Price on said turbo?
Old Feb 15, 2009 | 12:31 AM
KawBoy's Avatar
^^ Expensive
Supercharged06SS
Dec 11, 2022 04:47 PM
hacadacalopolis
Oct 28, 2015 06:09 PM
patooyee
Oct 15, 2015 05:11 PM
maliki778
Oct 1, 2015 07:39 PM
