turbo or supercharged
There's no computation agreed upon by anyone that would lead you to an answer to this question. You should search through the F/I and 2.2L performance section.
go turbo. pound per pound the turbo will make more power. turbo system is a lot easier to upgrade. the supercharger is great for power off the line. supercharger is definitely easier to install. both are reliable systems.
INSTALL: Supercharged
GAINS: If you plan on keeping internals stock then Supercharged. if down the line you want to build up the internals Turbo is wise.
DEPENDABILITY: Supercharged
but they really arent that far off in either category
if i had a manual trans i would turbo just because later down the line if i ever decided to it would be easy to buy some internals and up the boost.
but Supercharged is cooler
