TVS question
TVS question
Want to run a 2.7 pulley
Now how comparable would these numbers be
TVS + E85 + 80s + 100% distilled water injection
TVS + 93 + 80s + 50/50 meth/water
would rather run 93 because if i went on a trip wouldnt have to worry about finding E85
You would need bigger injectors to run a 2.7 pulley
You'd need to have a higher meth content to get timing where you want.
So the first set up would most likely net higher numbers.
Also, if you're gonna run a 2.7 with E-85, you will need a return style fuel system. The 80's on the stock fuel system won't be able to provide the fuel needed.
Iceberg
Sep 29, 2015 12:33 PM
