Twincharging - S/C & Turbo - Which comes first?
OK so say I have and S/C and a turbo does it matter if intake air goes into one compressor or the other first.
Does it matter?
Air>S/C>Turbo>Engine
OR
Air>Turbo>S/C>Engine
Also if inter cooler is after or actually between the the two FI devices.
I have heard different things and just want to get a quick answer if one is available.
Thanks
Does it matter?
OR
Thanks
Originally Posted by Halfcent
The air flow would be as follows. Ambient, filter, turbo, intercooler, super, aftercooler, intake, engine, exhaust, turbo, cat, muffler, ambient.
If done any other way will it cut power?
Depends, but in most cases yes it would.
This is assuming your using a roots or worm style super. If you put the super before the turbo, you loose a really big benifit, which is having the super help spool up the turbo. So just go with what Halfcent said.
