Forced Induction Turbos/Superchargers
Vacuum test help
Old Apr 17, 2015 | 05:28 PM
Dubz's Avatar
Vacuum test help
Hello! I'm trying to test the vacuum levels of my engine so I know which spring to use in my Tial QR blow off valve. I've got a T coming off the exhaust manifold. The hose that is in my hand goes directly to the blow off valve. However, when I hook it up to the T and turn the car on, it does not register any vacuum levels at all. Am I testing in the wrong place for this?
Old Apr 17, 2015 | 06:07 PM
Sl0wbaltSS's Avatar
Wire it up like stock, then plug in the hose from the BPV to your BOV and the other end directly into the intake mani and do your test from that. Cover up the left nipple and the bottom nipple on the little solenoid to the left of the intake manifold and remove the vaccum tank.
Old Apr 17, 2015 | 06:42 PM
Dubz's Avatar
I'm not sure how the stock setup works and my bpv has a plate covering it.
Old Apr 20, 2015 | 11:30 PM
kzak104's Avatar
you have it hooked up to the exhaust manifold? huh?
theres a little dink that has a hose attatched to it right on top of the intake manifold, pop the hose off and test from there.
i use a 10psi spring in my tial Q btw.
the dink is the line going to the bov
Old Apr 21, 2015 | 11:15 PM
Dubz's Avatar
Yeah that's how it was when I bought the car. A co worker is telling me that I need to get a forge divertor valve and set it up like stock...but I have no clue how that interacts with having the recirculating blow off valve setup.
Old Apr 22, 2015 | 12:03 PM
Dubz's Avatar
My co-worker wants me to buy the forge divertor valve and open back up the plate blocking off the factory bpv and set up all the vacuum lines like his SS is stock. Is that really a good thing to do with an aftermarket recirculating bov setup?
Old Apr 22, 2015 | 08:02 PM
09outlander's Avatar
You need to hook up the Tial bov directly to the intake manifold as seen in the picture in post #4
Old May 2, 2015 | 02:06 PM
Dubz's Avatar
Hey sorry I've been super busy! Is the hose that I'm supposed to use the one that is a hard plastic one coming off the vertical plastic piece off the manifold?
turbochargedss2012
Sep 20, 2023 12:17 PM
hacadacalopolis
Oct 28, 2015 06:09 PM
Trav3480
Oct 1, 2015 08:17 PM
anotherslowlnf
Sep 29, 2015 03:52 PM
Adiaz1ss
Sep 26, 2015 11:51 PM
