Wastegate on Garret Turbo
i believe its set to 8psi, the 2.2 garrett kit that is, u can raise it with a boost controller, and u can run w/e psi u can w/out causing knock, heat is the main consern with higher compression, the more psi u run the hotter it is from the compression process, thus the more u can cool it, the more u can throw at it w/out causin knock, as for the engine itself it can handle what GM states is 250chp, although some cobalts are running aroun with 240whp with no issues
