Wet... Really Wet CAI Filter
Originally Posted by drizunkpenguin
Well the problem there is i Dont have the Stock stuff anymore.. When i put the SRI intake on 2 weeks ago i tossed the stuff. then i threw out the Goosenext tubing crap when i extended the intake
Originally Posted by tiny
id bet you got oil from the filter in your air sensor
Yea you need to drive more slowly with that CAI up in there. It probably was on it's way to vaporlocking. Had water up in the tube but eh air rushing aroudn and through it kept it up in the tube till you stopped running the engine. Just be glad you didn't gun it or you mighta had to explain the bent rod in the block that woudl have resulted from it.
buy an air bypass valve first of all
secondly, id bet you got oil from the filter in your air sensor
