Forced Induction Turbos/Superchargers
What pulley?
Old May 12, 2008 | 10:13 AM
Cyclone's Avatar
What pulley?
What is the smallest pully that can be used on the gm stage 2 tune, i dont wan to go too small and loose power due to iat's and maxing out the injectors so what are my options 2.9,2.85,2.8???
Old May 12, 2008 | 10:17 AM
CobaltVenomSS's Avatar
2.9!!! but i got a 2.85 and i think i lost power..but that was with a clogged cat lol
Old May 12, 2008 | 10:18 AM
Cyclone's Avatar
lol that sucks i hope i dont get a clogged cat!
Old May 12, 2008 | 10:19 AM
yea it sucks lol...im getting a hi flow cat when my car gets out of the body shop
Old May 12, 2008 | 10:25 AM
dzld's Avatar
How about the Cobalt-Addiction SS GM STAGE 2 Replacement 2.79" Pulley? Anyone use that? Do you use the same belt that comes witht the Stage 2 kit?
Old May 12, 2008 | 10:37 AM
Cyclone's Avatar
I haven't heard of any one running that! And yes i go the stage2 gm belt if that is what you are asking.
Old May 12, 2008 | 10:46 AM
anthonyS88's Avatar
Unless you want to be doing a rebuild on your motor, i wouldnt.
dont go below a 2.9 pulley on the stage 2 tune.
Old May 12, 2008 | 10:50 AM
Cyclone's Avatar
So a 2.9 is as far as i should take it unless i get a better tune.
Old May 13, 2008 | 09:48 PM
Cyclone's Avatar
any one use the cobalt addiction 2.79 pulley
Old May 13, 2008 | 09:53 PM
Xenozx's Avatar
I have the 2.8 pulley boys, that was built specifically for the GM stage 2 hub.
25000 miles, problem free.
I have 37000 miles on my car, and trust me when I say Ive driven this car HARD! atleast 10 track trips, which = 60+ runs.
Much street racing (in my past)
lead foot driver
stage 2 tune, intake, exaust, high flow cat (think I shot the catalyst out the back tho lol), high flow DP, Header, 2.8 inch pulley, etc etc etc.
Stock clutch too, just as strong a day 1.
I run 13.4's, so you can imagine the power I am making, and havent had to "engine rebuild"
I think the 2.79 would be fine, but if you go lower, you will definately need to get tuned.
I look at it like this. Stock 32 lb injectors handled 3.3 inch pulley. to go to a 3.0 (gm stage 2) 42's were needed. so dropping down to 2.8 is borderline new injectors, but you should be able to get by scott free.
Old May 13, 2008 | 11:05 PM
XCRuna1201's Avatar
just go 2.9....2.8 you wont see much change form 2.9. You wont strat to see high PSI gains from the 2.9-2.8 until you get the 2.7 or lower which you will need the 60#'s and a new tune...
Old May 13, 2008 | 11:16 PM
Cyclone's Avatar
Cool thanks guy's
Old May 13, 2008 | 11:21 PM
rico's Avatar
stage 2 wit 2.8 with h/e and maybe dual pass should be fine right?
Oct 20, 2015 09:56 PM
SSLOW06
Oct 1, 2015 07:21 PM
patooyee
Oct 1, 2015 01:07 PM
Sep 30, 2015 07:22 AM
ChrisTutoki
Sep 24, 2015 08:39 PM
