Forced Induction Turbos/Superchargers
why is this so?
Old Jun 3, 2008 | 09:33 PM
mike25's Avatar
why is this so?
well i bid ona tial on ebay and in the auction the guy said he couldnt use the bov because it wouldnt work with his maf(evo) this sound right to anyone?
anyone
Old Jun 3, 2008 | 09:55 PM
Matt M's Avatar
Since TiAL 50mm BOVs relieve pressure into the air without provisions to reroute it back into the intake tubing, they can not be mounted after the MAF sensor without causing false MAF readings and driveability issues when they open.
Old Jun 3, 2008 | 10:01 PM
mike25's Avatar
i know that...but couldnt he easily make his setup a blowthrough style one?
Old Jun 6, 2008 | 01:14 AM
Jn2's Avatar
Jn2
have u seen the tial BOV's? they have no where to hook up a line to route the air towards the intake tract...they are relase in a full circle, not thru a barrel like others...we should be fine as we can mount the BOV before the MAF makin it so that it only reads it once, or locate the MAf on the intake side to mount the BOV whereever you want
Old Jun 6, 2008 | 10:26 AM
mike25's Avatar
yea theyre not meant to be used a recirculation valve...just a bov
Old Jun 7, 2008 | 10:10 AM
Maxim_X's Avatar
Not recirculating a draw through setup is bad. Trust me. It hurts the drivability. He probably knew that.
Old Jun 7, 2008 | 10:35 AM
mike25's Avatar
well i know its bad but why wouldnt he just try to convert to blow through? have to retune everything?
Old Jun 10, 2008 | 03:32 AM
Jn2's Avatar
Jn2
might, but retuning for a BOV is not worth it, so did you win the bidding?
Old Jun 10, 2008 | 04:58 AM
2K5SS/SC?'s Avatar
Making a blow through would require new charge piping and most definitely retuning. Evo's, just like STI's are very sensitive when it comes to the ECU.
Old Jun 10, 2008 | 05:18 AM
Jn2's Avatar
Jn2
and they have expensive to fix cheap glass tranny's
Old Jun 10, 2008 | 10:06 AM
mike25's Avatar
yea the tuning was mainly what i thought the problem was
