Forced Induction Turbos/Superchargers
Z54 or Z57
Old 09-01-2022, 09:14 AM
  #151
Tdubbs's Avatar
That happened between my first and second Z54. When the second one went on I was already planning to have the tune modified, but same tune that took first turbo to 25psi pegged the second at 30.
All that Dave modified was the WGDC real quick and it was back to being the same.
Old 09-01-2022, 09:48 AM
  #152
slapbetcommissioner's Avatar
Originally Posted by ECaulk
You should be looking at the LoRes sensor (that is the one in the charge pipe) as it can be viewed above 255kpa vs the intake manifold map sensor that is hard coded to max at 255kpa. Also don't forget to log the baro so you can subtract the baro from the LoRes sensor to get the boost pre throttle body
Thanks. I knew it was called something different!
yeah I log baro for that reason!
Old 09-01-2022, 09:49 AM
  #153
okay excellent. Mind at ease. I figured this was a big possibility
Old 10-22-2022, 11:50 AM
  #154
ionRL_585's Avatar
Almost about 5k on it now and still boosting hard! Raced a random Golf R no brake boost etc and had him by a car. Can't wait for next year for E and some head work and see what she can do 🙌🤙
AfterShok (11-07-2022)
Old 11-07-2022, 10:51 AM
  #155
AfterShok's Avatar
Give a 10-15k review when you reach there as that's where many have seen the failures. Good to hear it is running strong though currently! Do you ever log with HPTuners?
ionRL_585 (11-27-2022)
Old 11-27-2022, 11:10 PM
  #156
ionRL_585's Avatar
oh yeah for sure I just like keeping the forum alive as much as I can hah. Car is away for the season and currently deciding if I am gonna go E47.
You guys think I'll be ok on E47 with the Z54 on stock fueling system?
Old 11-28-2022, 07:37 AM
  #157
Tdubbs's Avatar
I can't say 100% but I'd assume so, depending on how aggressive you want to go.
When PWerks tuned my second Z54 I had redone all the timing and added the fuel lobe cam since I was in there, and he said based on numbers he didn't think it would have been needed. Always good to have extra I guess, as I use the same setup for e blend on the Z57BB too.
ionRL_585 (11-28-2022)
Old 11-28-2022, 12:19 PM
  #158
ionRL_585's Avatar
good to know thanks bro! ZZP tried selling me fueling mod haha. I am going to get the cam and opels later but if I can get by with E47 with the stock fueling system then **** it.
Old 11-29-2022, 12:24 AM
  #159
E47 on stock fuel system will be on the outer limits of the fuel system for sure. Really depends how much you turn up the boost.
ionRL_585 (12-01-2022)
Old 12-01-2022, 09:00 PM
  #160
ionRL_585's Avatar
I found a 7163 for sale which I may have to pick up. E85 might have to wait another season 😪
Old 12-02-2022, 09:52 AM
  #161
Yeah that turbo will outflow your fuel system for sure. Especially on e.
krome_dome
09-23-2022 02:07 AM
Dream20b
06-08-2014 03:18 AM
alexofnazareth
11-24-2013 10:18 PM
scopedmp5
02-01-2011 11:04 AM
40rty
06-22-2010 12:02 AM
Quick Reply: Z54 or Z57
