Forced Induction Turbos/Superchargers
ZFR vacuum lines?
Old Jan 16, 2016 | 02:01 PM
revready's Avatar
ZFR vacuum lines?
ZFR turbo. I am getting ready to start my car with the ZFR. I have one vacuum connection on the turbo where the electrical connection is that is not hooked up. I can not see any where to connect it to or does it just get plugged off? Can anyone help. Thanks
Old Jan 16, 2016 | 04:35 PM
Omiotek's Avatar
Waste gate?bpv? Which solenoid did you use. Are you talking about an actual line or just the open port on the solenoid? You need to be more clear or provide pics
Old Jan 16, 2016 | 04:45 PM
Gregman2016's Avatar
Any
Any of you in Georgia?
Old Jan 16, 2016 | 05:15 PM
revready's Avatar
Thank you for replying. I figured it out. I went on the Borg-Warner website and looked it up the EFR. The open line was a vent line. so I just left it alone. There was also a place where it looked liked something bolted to it. I wasn't certain about that either but what it wound up being was a port for an optional turbine speed sensor. I thought that was interesting. I got the car running a just warmed it up but have not driven it yet. I installed the new PCM that ZZP sold me tuned for my car but now it won't start because of the security. So now I have to figure that one out.
Old Jan 16, 2016 | 06:17 PM
Omiotek's Avatar
Yep so you ment you have an open port on the solenoid not a vaccun line. Its left as a vent. The speed sensor port needs to be drilled out for the sensor. Its somdthing only the indy cars use. Ive never seen it on a street car yet
Old Jan 16, 2016 | 08:57 PM
revready's Avatar
The vent is on the boost controller. It confused me because the stock turbos controller did not look like the ZFR. So I thought it had to be something there. The speed sensor port was deep and just seemed like something was missing there. The Borg Warner website for the EFR explained it all. I did take it for a short ride tonight goosed it a little. Seems to make more power than the stock turbo at lower boost pressure. You can definitely hear the BOV even though its internal.
Old Jan 16, 2016 | 09:12 PM
revready's Avatar
I am not to crazy about the oil feed line so close to the exhaust manifold and the O2 housing and with no heat shield. I got some Thermo shield heat wrap so I will try that. I got of stuff cooking off the exhaust like anti seize and possibly because it's all new. As I was installing the ZFR I was reading a lot about it killing transmissions especially with the 3.82 final drive. So I am hesitant on getting down on it especially 3rd gear the weak gear in the F35. I am looking next into the trans mounts and motor mounts to help with any possible wheel hop and then trans with the 4.45 final or the 6 speed F40 I've come this far. I want to do it right.
Old Jan 16, 2016 | 10:27 PM
Omiotek's Avatar
Nothing is bullet proof. The best thing you can do is become a good driver and a full face disk in your clutch assembly. Your trans will last long. I had 450 ft lbs on a stock trans and it wasent even close to gernading.
Yeah thr oil line for the zfr is to short in my opinion. Im not a fan. The stff burning off is from touching it. Its normal.
The biggest thing you want to do is eliminate wherl hop. Good trans mounts and control arm bushings
Old Jan 16, 2016 | 10:43 PM
revready's Avatar
I have the South Bend stage 4 clutch. I have been in contact with John Powell regarding transmission and mounts. I haven't had any wheel hop even with the stock turbo on a tune but don't want to take any chances. I now have the ZZP PCM set up for my ZFR. I had Trifecta with the stock turbo. I went with ZZP cause they have done a lot with these cars and know their stuff. What final drive do you have in your trans? Have you had your ZFR long. Any tips since I am a ZFR newbie. How is the turbo heat in the hot weather under the hood?
Old Jan 17, 2016 | 12:08 AM
nathan112i's Avatar
wrapping the oil line with heat wrap was a good call, if you email zzp they can make an oil line up for you thats a bit longer. being that its a water-cooled turbo i wouldn't lose any sleep over temps under the hood. power delivery is going to determine how reliable your transmission will be, have power come on softer and linear rather than a huge spike and you will have no problems.
Old Jan 17, 2016 | 12:16 AM
Omiotek's Avatar
Like i said in my.post bone stock trans. 3.82. Never had issues with it but i dont drag race i road race. The car had a 5557 and a 6758. 35k i had on the trans and stock engine before the car was totaled.
Old Jan 17, 2016 | 12:36 AM
revready's Avatar
Nathan112 I was actually thinking about that longer line deal I just might contact ZZP on that. Thanks
Omiotek, totaled that sucks. Did you replace it with another Balt.
Old Jan 17, 2016 | 02:38 PM
Omiotek's Avatar
yeah but it has no go fast bits
Old Jan 17, 2016 | 09:15 PM
revready's Avatar
I guess you'll have to work on that
Old Jan 17, 2016 | 11:55 PM
Omiotek's Avatar
na i just dont care for it anymore. i know whats ideal for me in this car and im not into drag racing or roll racing. 400whp is plenty for me
Old Jan 18, 2016 | 01:41 AM
revready's Avatar
Its a fun little car. I don't race it but its like a project car to play with. I want to have the power just in case someone does try a to pick on me going down the road. Plus having the mods that I have separates it from most others. I got to get used to this ZFR though.
Old Jan 18, 2016 | 09:35 AM
Omiotek's Avatar
Most of these cars are modded. Trying to find unmodded ones is hard. Not.to mention fonding one that hasent had a crap tune
droponikz
Jan 30, 2016 08:00 PM
jcalvin1126
Jan 29, 2016 03:07 AM
kzak104
Jan 16, 2016 01:16 AM
The Rookie24
Jan 13, 2016 07:32 PM
no_ss
Jan 11, 2016 11:01 AM
