Forced Induction Turbos/Superchargers
ZZP Build Questions
Old Aug 27, 2012 | 12:28 PM
cobalt523's Avatar
Talking ZZP Build Questions
so im buying the zzp turbo kit for my 2.2 Auto LAP, and they give me optoins like do i want the 256, 252 extended, or the 256 extended? whats is better? and explain please....learning! also external wastegate dump or wastegate dump into exhaust? and is the Tial Q BOV 50mm really worth an extra 130$ ??
Thank You
Old Aug 27, 2012 | 01:39 PM
Nfamous60's Avatar
depends on ur power goals, 256et seems to be the most powerful and can provide a broad range of power. others with the kit would better be able to explain though.
Old Aug 27, 2012 | 01:40 PM
cobalt523's Avatar
Ok thanks, what does the extended tip do?
Old Aug 27, 2012 | 01:47 PM
Superbalt06's Avatar
The extended tip turbos halve a surge ported compressor housing. Also The extended tip is supposed to flow more air without sacrificing spool time.
Old Aug 27, 2012 | 01:50 PM
cobalt523's Avatar
So the 256ext would be best ok, and do you think my engine and auto trans can hold?
Old Aug 27, 2012 | 02:01 PM
About 2fiddy. Need to build your motor first.
Old Aug 27, 2012 | 02:05 PM
cobalt523's Avatar
I heard close to 3hunned but what do you suggest? Rods and pistons? When people say build your engine what do they mean?
Old Aug 27, 2012 | 02:07 PM
cobalt523's Avatar
Trying to go fast not broke
Old Aug 27, 2012 | 02:10 PM
Bought the wrong car if you want to go fast.
Old Aug 27, 2012 | 02:13 PM
jonathan923's Avatar
this. or you wont last a week
Old Aug 28, 2012 | 12:16 AM
Rods and pistons are the basics. But if you want to rev higher you have to do head work and neutral/delete balance shafts. Good idea to do rod and main bearings too. Crank and block are good for your goals.
on the trans idk. 5>4
Last edited by Slowbalt2000; Aug 28, 2012 at 12:16 AM. Reason: Automerged Doublepost
Old Aug 28, 2012 | 05:44 AM
cobalt523's Avatar
hhhhhmmmm too mush work for now lol how just stage 2 ki with regular 256?
Old Aug 28, 2012 | 09:06 AM
that all depends how much you want out of the car. you go past 250whp on your 2.2 and it starts to get very unreliable..sorry
Old Aug 28, 2012 | 09:14 AM
BankerBalt's Avatar
unless you have money to quickly rebuild your engine after buying a turbo kit, i would suggest buying internals and do some head work first. i did the opposite and it killed me financially
Old Aug 28, 2012 | 09:21 AM
Ryan@zzp's Avatar
I would recommend the 252ext. The 252ext turbo would respond very fast on your 2.2. Since you don't have a lot of room in terms of hp before you reach your engines limit, this turbo is a great match for what you have. Good low, mid, and top end pull=great powerband=winning races.
Old Aug 28, 2012 | 09:26 AM
cobalt523's Avatar
The peoples will ask, "Y U No Lose Boost?" and I be like "Automatic!"
Old Aug 28, 2012 | 10:37 AM
cobalt523's Avatar
Thank You and which Bov is louder? ZZP 50mm or Tial 50mm?
Old Aug 28, 2012 | 10:43 PM
cobalt523's Avatar
bumpity
Old Sep 2, 2012 | 10:55 AM
DFZ24's Avatar
they are just BOV, they will just blow air the sound is not that loud.
i have tial q and you can hear it inside the car, but i dont think it goes outside the engine bay lol
you could just save alot of money, buy the built engine from zzp and the turbo kit, and bam you are set
of course..... handling have to be upgrade too..... pads, rotors, maybe lines, etc etc etc unless you want to be fast and have no way to stop quick...
Old Sep 2, 2012 | 11:09 AM
cobalt523's Avatar
yeah its going to be a long process to get the car how i want hhaha
Old Sep 4, 2012 | 09:10 AM
Ryan@zzp's Avatar
They sound the same.
Old Sep 4, 2012 | 10:01 AM
cobalt523's Avatar
awsome thanks
brandon04
Oct 21, 2015 07:04 AM
no_ss
Oct 18, 2015 11:58 PM
patooyee
Oct 15, 2015 05:11 PM
