Discussion: best method
So thus is something I've been thinking on for s while and never remember to test.
When you're trying to preserve that lovely precious liquid in the tank, what's best?
Putting around waiting to get to your desired speed?
Or hauling a little ass and getting where you want to faster then coasting?
This question is mindfucking me. So please give me some opinions.
I've found that if you slowly accelerate for a long time, you put the engine under load for a longer amount of time, wasting more fuel. It works better for me just to get up to speed, and go the speed limit.
just get up to the speed limit and your fine. From a stop and accelerating as long as you don't go into boost, thats the best way your going to conserve fuel. That or take public transportation or walk if your only going to the corner store lol.
What works for me is to shift around 2500-3000 rpm's in each gear. Even lower works in the higher gears. If you are going to be cruising around 50 mph or so, put it in 5th. Just don't stap the gas when you want to go. On my daily drive, I am averaging 29 mpg.
Try and keeping the boost low helps too. Going the speed limit helps too. I have noticed with mine, that if I go over about 74 mph on a long trip, it goes south fast. The best that my car has done was 37 mpg doing 68 mph with the air on.
Also, have your windows up. Use the areodynamics of the car. Have the a/c on low. The newer cars are made to run like this on the highway.
Generally, I accelerate more slowly than the traffic around me and I shift around 2300-2500. If I am going up a hill, I'll shift around 3000. If I am going down a hill, I'll shift around 2000.
If I am cruising around town at 35 mph, I'll leave it in 4th gear. Any faster, and I'll shift into 5th.
There are two things that rape my fuel economy. The main one is wind, and the second is speed.
I hope this helps you out. You know our cars are identical...
In my opinion, somewhere in between is the sweet spot. If you accelerate too fast, you're just wasting gas. If you accelerate too slowly, you'll always have a load on the engine and it will take a lot longer before you can let off the gas.
Maybe the difference is in our engines. How does the low-end torque in my mostly-stock 2.4 compare to the low-end torque of your 2.0 SC with a long-tube header?
Only if you are trying to accelerate or drive up an incline. I've noticed a little bogging with a stiff head wind, but I'd hardly call it "hardcore".
5th gear is useless until you hit 45 - 50 mph.
I can't really say anything becaust I averaged 17 mpg on my last tank of premium.
RA080424
Show & Shine
47
Mar 20, 2007 04:35 PM
PpAzZ1101
Apr 25, 2006 07:53 AM
