Fuel Economy - Hypermiling Dedicated to discussions on fuel economy improvements and related modifications.
Easy mileage improvement
Old Aug 6, 2008 | 07:05 PM
  #51
thekingsSS's Avatar
Originally Posted by an0malous
bingo.
gotta go to work. ill dig into this more with you tommorow if you like.
but i can almost garuntee its the tune.
Word, maybe I can get you a copy of a log or something and you can see what you can do. You seem to be pretty good at getting awesome mileage in these cars
Old Aug 7, 2008 | 01:38 PM
  #52
an0malous's Avatar
Originally Posted by Tomtwtwtw
For what it's worth, I've noticed that in my car, DFCO only appears to activate in 5th, and cuts off when the car goes below 1250 rpm. I've taken it up to 60 in 4th and just let off the gas, and if it were cutting fuel 100%, the instant readout would peg at 99mpg right away. Only does this in 5th.
hmmm thats rather interesting too.
im assuming your on a custom tune as well?
whos tune are you running?
its pretty common for people to turn off DFCO during tuning, so its quite likely they may just have forgotten to re-enable the engagement qualifiers.
Old Aug 7, 2008 | 02:59 PM
  #53
csementuh's Avatar
The DFCO is much more apparent if you have a wideband AFR gauge to monitor...
Idling or cruising very slightly on the gas my LC-1 w/ DB-Red reads around the 14.7 range... If I am fully off the gas and coasting in gear, it will read 22.4 (or some gauges read "lean" or "error" as they don't go that lean). This is also the reading the gauge gets when the O2 sensor is completely in open air. Soo this is accurate, the exhaust is ALL air, NO gas...
DFCO is real and it does work. If it isn't working, and your tuned, it was probably turned off...
Old Aug 7, 2008 | 03:25 PM
  #54
Tomtwtwtw's Avatar
Stock 2008 ss
Never watched it on the old car, since it didn't have the instant readout, but it's pretty easy to notice when you have the DIC telling you your instantaneous mileage.
Old Aug 11, 2008 | 03:14 PM
  #55
rcmpayne's Avatar
DFCO is proven to be better with a MT then a AUTO but my question is in a auto will DFCO be better then in natural?
Old Aug 26, 2008 | 01:38 PM
  #56
VetteVert's Avatar
SS/TC's as well?
Old Aug 26, 2008 | 04:33 PM
  #57
captmrwill's Avatar
Yeah, I've noticed similar, sort of. It seems as though the DFCO on my SS/TC (08) kicks in when coming from above 2750 and through roughly 2250 (if I'm remembering correctly), judging by the INST on the DIC. Downshift and have revs below 2750, your not at 99. Let it fall below 2250 on the coast, and it drops from 99.
I don't know if that's the way it is designed or what, but that's what I've noticed.
Oh, and yes, that's not in fifth. Fifth seems to be 99 on a coast.
Old Aug 26, 2008 | 04:52 PM
  #58
D4u2s0t's Avatar
after you go below a certain rpm, the injectors kick back on. i'm not sure what it is, in my car it doesn't seem to matter what gear i'm in, but somewhere right below 18mph you can feel the injectors come back to life.
Old Sep 5, 2008 | 03:10 AM
  #59
tiny's Avatar
i wonder how much gas you use when you downshift instead of putting it in neutral to stop
I would imagine giving the pedal a "blip" of gas for each gear would amount to more than the idle amount
Old Sep 5, 2008 | 10:28 AM
  #60
an0malous's Avatar
try it and see.
ive tested it countless times, but no one will believe me anyway
Old Sep 5, 2008 | 10:40 AM
  #61
D4u2s0t's Avatar
when you downshift you're using ZERO gas. the fraction of a second blip is nothing, all you're doing is raising the rpms a little bit in neutral.
Old Sep 8, 2008 | 04:33 PM
  #62
kazinova's Avatar
Has anyone here gone to standard transmission driving school? Yeesh!
Downshift to slow yourself down over a long coast or going down a hill.
Saves gas.
Saves brakes.
Saves lives.
What is there to argue about. Forget what phantom "improvement" you may think you get doing something. People drive manuals this way for a reason. GET OVER IT.
Old Sep 8, 2008 | 04:38 PM
  #63
an0malous's Avatar
prepare to be frustrated lol.
we have been saying this stuff for years, the kids still think neutral coasting is ftw, and rarely listen.
Solaris99
28
Mar 15, 2017 01:22 PM
Extreme Dimensions
Pontiac G5 Appearance
Oct 28, 2015 01:52 PM
Extreme Dimensions
Extreme Dimensions
Sep 24, 2015 07:51 PM
medic710
Sep 6, 2015 08:53 PM
