Fuel Economy - Hypermiling Dedicated to discussions on fuel economy improvements and related modifications.
low mpg
Old Nov 12, 2010 | 09:24 AM
ThisSubtleDagger's Avatar
low mpg
Hey forum, just curious if maybe anyone had some advice for me.
So I drive a 08 Cobalt Sport, still completely stock and I only get 21-23mpg. I'll admit I don't drive the best in town, always taking off at lights, but my buddy has a 06 SS and he drives it WAY harder than I drive mine, and gets 26-30.
Also we take the same road to get to our jobs (highway) and 90% of the time I just cruise control at 68/69 mph.
Could there actually be something wrong?
Old Nov 12, 2010 | 09:27 AM
Turbalt2010's Avatar
drive it like you stole it! maybe your milage will go up
Old Nov 12, 2010 | 10:06 AM
Lol..
5 jokes to 1 real answer, seems that's how topics always go for me.
Old Nov 12, 2010 | 10:19 AM
TractionControlWTF?'s Avatar
stop using cruise control.
Old Nov 12, 2010 | 04:56 PM
Nal's Avatar
Nal
remember, your engine will always work harder then his, so it's not uncommon, I ride my gears and like to get hugged by the car when the lights turn green, and I see 28-33 avg...
Old Nov 12, 2010 | 05:03 PM
springerdesigner's Avatar
that 10% of HARD city driving is bringing your mileage down...
best thing you could do for gas mileage is buy a brick and put it under the right pedal in your car.
Old Nov 12, 2010 | 08:02 PM
army_greywolf's Avatar
Well, 9 out of ten times you can get better mileage by adjusting your tire pressure and/or replacing tires that are worn OR more than three years old (check the manufacture date on the sidewall not the date you had them installed) other factors include worn shocks/struts which in a newer car is unlikely, but you should have your alignment checked, even if it's not off that bad, for sixty bucks you can make that up at the pump in a couple months, and it'll save on tires and component wear.
Other things you should check, jack up each axle put everything in neutral/parking brake off and roll each tire by itself check for binding, should feel little resistance. Finally every 50 or so pounds you carry without increasing your tire pressure to compensate can take .2 or more off your mileage. Transmission fluid condition can affect mileage as well, even where you get your gas. Anywho, good luck.
Old Nov 14, 2010 | 12:44 PM
Blue_Balt's Avatar
Take off nice and easy from lights. I bet that's dragging you down quite a bit.
Old Nov 17, 2010 | 09:29 AM
xxxxsh4d0wxxxx's Avatar
Plugs, fuel filter, seafoam, use synthetic oil, carry less **** with you, don't drive like a dick, tire pressure.
Old Nov 17, 2010 | 09:59 AM
shabodah's Avatar
Is it an Automatic? (Yours)
patooyee
Oct 15, 2015 05:11 PM
importkiller
Sep 30, 2015 07:18 PM
Slick_Nick
Sep 28, 2015 09:15 PM
OPCrer
Sep 27, 2015 08:11 PM
dieGone
Sep 23, 2015 10:20 AM
