Terrible gas mileage!!
Ok, lately ive been getting absolutely terrible gas mileage! it shows i get 18 miles per gallon!! i think it started happening after i put my new rims and tires on. i recently put 17s on with bfg kdw tires. also my light for the tire pressure sensor is on. could that be the problem?
For winter the oil companies make a different mix when they produce the Gasoline. if you really want to know read this
http://epa.gov/otaq/regs/fuels/ostp-3.pdf
Hmm well I thought the mileage difference was due to things like warm up taking longer (richer fuel mixture for longer), and the atmosphere is more dense. More o2=more gas for stoich.
Oh well i could be wrong.
mileage
if you changed the rim size, the computer is calibrated for a specific size and thats what it goes off of for you fuel mileage computer, soif you changed tire or rim size your computer would be off try calculating it the old fasioned way by filling it up to full, setting the trip, driving it for awile and filling it back up again and dividing it by the mileage you accumulated and the gallons that you had to replace. and see if it ising off a gallon or two? could be and also winter mix gas sucks.
and consequenctly it would be off the same ammount but by a %
So even if you do the fill up reset and math you should STILL get
close to the # on the display.
i was gettin tht on my ride, with the stock rims n such, i cleaned my air filter (dirt dumped out) and changed the plugs and ran higher grade gas and my mileage came back up to where it was before i neglected it for a wile
I just got back from a long trip this weekend. I averaged 32.5 mpg on the highway today, with my winter tires. Before I was getting only about 20 mpg, and that's mostly highway going to work. The temps have been warmer (around 32), opposed to the single digits and teens. The bitter cold must really decrease the gas mileage.
roth
Sep 26, 2015 12:16 PM
