Using the F35 from the 08-10 SS with LSJ
From my understanding these are basically the same tranny but the 08-10 has a 3.82 or something ratio and the 05-07 is a 4.05? so less revs more speed with the LNF tranny?
wouldnt this deliver slightly better fuel mileage having better gearing
i has one.....
http://www.fatboyraceworks.com/gears...raph&Compare=1
this is a good comparison chart.... i already put in the numbers
usdm08 here on the forums swapped an lnf tranny to his 07 lsj and saw some improvement in mpg he says. hope this helps. not sure about performance, but am pretty sure it delivers same if not better performace...
May have internal upgrades for the NLS, not sure on that though.
check out the link and try changing the rpm limits on both engines... the lsj with 7400 rpm limit(perfectly safe stock) does almost the same speed in each gear as the lnf at 7k on its tranny
ThoR294
Oct 4, 2015 08:44 PM
Sep 28, 2015 12:51 PM
