@ the dealer....getting sick of chevy
Old Jan 20, 2010 | 12:21 PM
Auddasea's Avatar
At the chevy dealer right now. My car took the ultimate ****. Got engine check light, abs light, t/c light, power steering goes out, rpm gas and mph needle goes up and down. After the initial diag they came back and said we don't know what's up we've never seen this before but all 3 of your computers may be replaced, and asked me if I could afford that. I almost laid his ass out. Anyone else had this issue? I'm not paying for a car all 3 computers went on. Period
Old Jan 20, 2010 | 12:22 PM
ls1fbody's Avatar
Haz l33t wheelz.
you no longer have a warranty?
Old Jan 20, 2010 | 12:27 PM
PSHHH's Avatar
this happened to me but with my LS...had to get a new fusebox put in the ground came off my amp and shorted out the whole system
Old Jan 20, 2010 | 12:39 PM
jonathan923's Avatar
WTF? is this an lsj? lnf?
Old Jan 20, 2010 | 12:50 PM
Auddasea's Avatar
Don't have the extended warranty. Its a 2007 lt2..... I have a system in my car but this was hapening way before I put the system in so if you did have those problems it wasn't due to your amp. Plus amps have fuses in them to cut the circuit if it double backs. This car ran great until 40k than started breaking like clock work.
Old Jan 20, 2010 | 12:52 PM
unijabnx2000's Avatar
nvm...
the fusebox under the hood?
Last edited by unijabnx2000; Jan 20, 2010 at 12:52 PM. Reason: Automerged Doublepost
Old Jan 20, 2010 | 12:56 PM
Auddasea's Avatar
^^ that's what I was thinking. You pull a ground off an amp and the amp just cuts off the circuit will never double back. I work at a car audio shop and we do this to cars all the time to test the ground connection cause were to lazy to use the little tool that tests the ground (forget what its called) and we've never had an issue. So chevy must be doing something wrong. Hell you can pull the ground off your own battery and nothing should happen. That's how you test the alternator
Old Jan 20, 2010 | 01:08 PM
^ false, you pull the + off the battery to test the alt,
pulling the neg will kill the car everytime. (from my exp)
Old Jan 20, 2010 | 01:24 PM
Auddasea's Avatar
Maybe your right. I forget. It was shown to me years ago.
Old Jan 20, 2010 | 01:30 PM
eurochevy's Avatar
isn't 07 5 year warranty?
Old Jan 20, 2010 | 01:38 PM
Auddasea's Avatar
^^ god I hope so. I've been here 4 hrs and they still don't know wtf is going on
Old Jan 20, 2010 | 01:51 PM
eurochevy's Avatar
ya i believe it was either 06 or 07 that they came out with all of them having a 5 year 160k km or in ur case..100mile warranty
Old Jan 20, 2010 | 01:55 PM
phillips01's Avatar
I work at a chevy dealer and it pisses me off when i here storys like that .I dignosis cars properly no guess work ,are their really that many hacks out their ?At our dealer if a tech miss dignosis ,it we pay for it....Storys like that make the good techs that dignosis car properly look bad .I say go to a different dealer ..
Old Jan 20, 2010 | 01:56 PM
SKCobalt's Avatar
My 07 Has the 5 year 160k km (100k mile) warranty. I would think that all 2007's would have it.
Old Jan 20, 2010 | 02:00 PM
eurochevy's Avatar
as does mine
Old Jan 20, 2010 | 04:06 PM
Auddasea's Avatar
Still at the dealer. Still don't know what's wrong. I wasn't aware it took 7 hrs to diagnose a vehicle by the dealer.
Old Jan 20, 2010 | 08:40 PM
kapster's Avatar
07 and up vehicles have the 5 yr 100k mile warranty. Dont let them push you around.
Old Jan 21, 2010 | 01:35 AM
Auddasea's Avatar
Found out what was wrong. 05 06 and 07 models have the wire harness to the ecu and bcm wired incorectly on certain batch. Check your vin numbers guys. If they have a 77 anywhere in them its bad luck. They rewired the ****, cleaned the pin connectors and called it a wrap. 165 bucks....car works perfect thank god. 165 is not to bad
Old Jan 21, 2010 | 09:04 AM
SKCobalt's Avatar
I really don't understand what you mean about the vin number. What digits are you talking about that have a 77 in them. Each number in a VIN means something. Is there a TSB out for this?
Old Jan 21, 2010 | 09:11 AM
LS6Rally's Avatar
not only that but if you have an 07 it shouldve been covered under warranty
Old Jan 21, 2010 | 12:43 PM
Auddasea's Avatar
If your vin has a tripple 7 in it than you may have this problem. Like my vin has 777 right in the middle of it. They said there's no recall on it because not all of them are doing it. There's only like 150 that have been entered in the system or some ****.
Old Jan 21, 2010 | 12:46 PM
myfakeevo's Avatar
if your car is under warranty why did you pay anything?
Old Jan 21, 2010 | 01:28 PM
Shibito's Avatar
x2...
You just got jacked by the dealer.
Old Jan 21, 2010 | 01:48 PM
Did they find out the problem yet?
Old Jan 21, 2010 | 01:52 PM
1badBlueberrySC's Avatar
Take that **** back... you have a warranty you shouldn't have to pay for ****. Sometimes I ******* hate dealers....
