for the 10th time...
for the 10th time, im taking the balt to the dealer to check on the suspension clunking noice , the first nine times the noice was on the front, now it is front and back...
Im sorry to say this but im getting tired of the balt..
Were they unable to fix it the previous times or does it keep comming back?
well the first 4 times,, it was "fixed" for about a month maybe 2 and then it came back,, but the last times,, its just back to back, I dont keep it at the dealer bc I need something to move at..
I want to sell it so bad. but I owe more that what its worth..
they have no idea, they have change, the struts, springs, suspension plate, steering column, some rubber bushings... they one time blame the brakes, so they change that, also they change the hood latch and still...
ok,, new problem,, so I took it to the dealer, and apparently ether my mom or my sister run over a bump on the road, or something, that busted the two rear rims and shocks, and scratch the bottom of the car..
so I need to fix them rims, and well at least the warranty will cover the shocks
a little advice
everything will usually come back when it's made in some 3rd world country or Mexico.....regardless of how many times you replace it
upgrade to aftermarket **** if you're concerned with the noise
Ill probably end up doing that,, bc on February my warranty will end..
is the noise when u stop and then go again or when u turn the stearing wheel??
It's your sway bar endlinks. Guarantee it. Remove them, drive for a week, see if sound goes away. Unfortunately you can't keep them off or the sway bar will rotate and knick the control arms, but take BOTH endlinks off and drive for a bit and see if the problem goes away.
oh cuz mine makes noise when i do the things i said b4. but thats been ever since i installed my shocks n springs. i took it bak to the guy that did the work and he checked everything or atleast said he did and he said everything looked fine. i dunno what it could be. the noise comes from the front on the right.
Mine did too, it's the joints on the endlinks. Mine would come and go and it sounds awful like something is seriously busted and/or going to fall off the car. Took the end links off, sound never came back no matter waht I tried. Put end links back on and the sound returned IMMEDIATELY.
well my suspension is stock in front, and rear ss/sc springs in the back... and I never had problems in the back till a month ago,, and now its "fixed" but, I had to pay bc somehow my rims got bended,, and its not even real noticeable ...
