for the 10th time...
Old Jun 3, 2008 | 11:08 PM
Belto's Avatar
Thumbs down for the 10th time...
for the 10th time, im taking the balt to the dealer to check on the suspension clunking noice , the first nine times the noice was on the front, now it is front and back...
Im sorry to say this but im getting tired of the balt..
Old Jun 3, 2008 | 11:11 PM
Red2.4SS's Avatar
Pretty strange!
Were they unable to fix it the previous times or does it keep comming back?
Old Jun 3, 2008 | 11:36 PM
Belto's Avatar
well the first 4 times,, it was "fixed" for about a month maybe 2 and then it came back,, but the last times,, its just back to back, I dont keep it at the dealer bc I need something to move at..
I want to sell it so bad. but I owe more that what its worth..
Old Jun 3, 2008 | 11:37 PM
LilHaile's Avatar
I would try going to a different Dealer... And maybe they could fix it...
Old Jun 3, 2008 | 11:39 PM
Belto's Avatar
ive try 3 diff dealers and also GM send a guy supposedly "the best in the area"
Old Jun 3, 2008 | 11:42 PM
hatrickstu's Avatar
so what have they told you is the problem?
Old Jun 3, 2008 | 11:45 PM
Belto's Avatar
they have no idea, they have change, the struts, springs, suspension plate, steering column, some rubber bushings... they one time blame the brakes, so they change that, also they change the hood latch and still...
Old Jun 3, 2008 | 11:47 PM
dsp86's Avatar
did they ever change ur sway bar endlinks?
Old Jun 3, 2008 | 11:49 PM
Belto's Avatar
I believe so.. at one point the change the complete front suspension.
Old Jun 4, 2008 | 12:07 AM
Red2.4SS's Avatar
Wow! Sounds like they have gone through everything!
Wonder what could be left?
Old Jun 4, 2008 | 12:28 AM
LilHaile's Avatar
Get a lawyer and make them just give you a new car since they can't fix it.. Can you do some sort of lemon law on it or anything like that?
Old Jun 4, 2008 | 11:01 PM
Belto's Avatar
ok,, new problem,, so I took it to the dealer, and apparently ether my mom or my sister run over a bump on the road, or something, that busted the two rear rims and shocks, and scratch the bottom of the car..
so I need to fix them rims, and well at least the warranty will cover the shocks
Old Jun 4, 2008 | 11:33 PM
nhanson's Avatar
never let your mom or sister drive the car again....
Old Jun 4, 2008 | 11:53 PM
Mr_Slobalt's Avatar
a little advice
everything will usually come back when it's made in some 3rd world country or Mexico.....regardless of how many times you replace it
upgrade to aftermarket **** if you're concerned with the noise
Old Jun 5, 2008 | 08:31 PM
Belto's Avatar
Originally Posted by Mr_Slobalt
a little advice
Ill probably end up doing that,, bc on February my warranty will end..
Old Jun 5, 2008 | 08:41 PM
chrism0589's Avatar
is the noise when u stop and then go again or when u turn the stearing wheel??
Old Jun 5, 2008 | 08:43 PM
Belto's Avatar
is every time I go over irregular roads (witch is everyday in PR) or speed bumps,,, it sounds like a busted shock but, sometimes,, the shocks are "ok"
Old Jun 5, 2008 | 08:46 PM
alleycat58's Avatar
It's your sway bar endlinks. Guarantee it. Remove them, drive for a week, see if sound goes away. Unfortunately you can't keep them off or the sway bar will rotate and knick the control arms, but take BOTH endlinks off and drive for a bit and see if the problem goes away.
Old Jun 5, 2008 | 08:47 PM
Belto's Avatar
the sound comes and goes as it pleases,, but ill try
Old Jun 5, 2008 | 08:48 PM
chrism0589's Avatar
oh cuz mine makes noise when i do the things i said b4. but thats been ever since i installed my shocks n springs. i took it bak to the guy that did the work and he checked everything or atleast said he did and he said everything looked fine. i dunno what it could be. the noise comes from the front on the right.
Old Jun 5, 2008 | 08:50 PM
alleycat58's Avatar
Mine did too, it's the joints on the endlinks. Mine would come and go and it sounds awful like something is seriously busted and/or going to fall off the car. Took the end links off, sound never came back no matter waht I tried. Put end links back on and the sound returned IMMEDIATELY.
Old Jun 5, 2008 | 08:51 PM
Belto's Avatar
well my suspension is stock in front, and rear ss/sc springs in the back... and I never had problems in the back till a month ago,, and now its "fixed" but, I had to pay bc somehow my rims got bended,, and its not even real noticeable ...
Old Jun 5, 2008 | 09:36 PM
Mr_Slobalt's Avatar
endlinks go every 20k-30k from what I've seen
Old Jun 5, 2008 | 09:40 PM
Belto's Avatar
my car has not gone to 20k yet..
Old Jun 5, 2008 | 09:41 PM
Mr_Slobalt's Avatar
well, that's average
