2.0 vs 2.2 cam cover, misc bolts
I have a 2.0 LSJ shortblock, cylinder head and valve cover that I have purchased and have access to a bunch of 2.2 2007 motor parts
I need the timing chain cover, oil pump, water pump, thermostat, timing chain and associated items. Am also missing a couple of camshaft bolts (that hold the camshaft bearing caps)
Is the 2.2 the same for these items?
I noticed that the 2006 LSJ camshaft bolts I had where different than the 2007 2.2 in appearance. I called two dealers and got two different answers (one said they were the same....and the other said they were different).
I have the factory service manual for both the 2.2 and 2.0 engine for 2006....but it does not give the part numbers in it. Trying to find out if I can use these 2.2 parts to complete the 2.0 build
