2.2 Tranny problems? Jerking with shift points
Old May 19, 2008 | 09:22 PM
Nickc84's Avatar
I just noticed the other day my gears are shifting hard once in a while like a jerk when it changes gearing. It has 46k miles I always service it ....what could be wrong>?
Old May 19, 2008 | 09:23 PM
SSRedSC's Avatar
Good peddle pressure? Might have a leaky master or slave cylinder. Check your clutch fluid level.
Or clutch, throw out bearing wearing.
Old May 19, 2008 | 09:27 PM
Nickc84's Avatar
its automatic
Old May 19, 2008 | 09:30 PM
sick06cobalt's Avatar
mine does it too with 23 k on it....
Old May 19, 2008 | 09:33 PM
Nickc84's Avatar
weird
Old May 19, 2008 | 10:02 PM
XM15's Avatar
Someone secretly installed the B&M shiftplus on you.
Maybe its time to change out your transmission fluid.
Old May 20, 2008 | 07:40 PM
SuicidalCobalt's Avatar
sounds like a tranny problem.. check the fluid.. more than likely ur problem
Old May 20, 2008 | 07:50 PM
BlackMachine's Avatar
tranny, does it only happen when your u got it to the floor or when ur just gradually driving
Old May 20, 2008 | 07:56 PM
tru2nrtt777's Avatar
Mine does it occasionally from a stop, kinda like if you just pop it into drive while sitting in neautral for a few minutes and have the throttle slightly open.
Old May 21, 2008 | 06:27 PM
YSUsteven's Avatar
I don't think there is a dip stick for the tranny fluid, the only way to check it is to change it. Its supposed to be good for 100,000 miles anyway.
Old May 21, 2008 | 06:58 PM
Tomtwtwtw's Avatar
Check your mounts, too. There's no way in hell they should be worn that early, but you never know. When mounts wear, they allow excessive movement of the tranny / engine, and that could be causing the jerkiness.
RaginChopsuey
Oct 27, 2015 01:27 PM
OrangeCoba
Oct 1, 2015 10:00 PM
Iceberg
Sep 29, 2015 12:33 PM
Iceberg
Sep 28, 2015 01:31 PM
DocSvensk
Sep 27, 2015 02:24 PM
