2nd gear
Old Dec 22, 2007 | 10:28 PM
srcobaltss's Avatar
2nd gear
when i powershift or launch 1st gear goes good. then when i hit second the rpms drop and it feels like it bogs out until the rpms get to about 2500rpms. then the car starts pulling how it should. my buddies cobalt does the same to him. whats weird is when i first got it. 2nd gear was my favorite gear. it was pulling hard. i was wondering if all cobalts did this and if so there was a way to change my driving to fix the problem
Old Dec 22, 2007 | 10:37 PM
an0malous's Avatar
stop spinning the tires through first, and expecting second to act properly.
your running through first, but your car isnt going the speed it SHOULD be going when you shift to second, because you spun to much.
your lucky its only bogging and your not tearing your clutch to shreds.
Raven SS's Avatar
sounds like u have tire slippage...u cant put it in 1st dump the clutch and mash the pedal and expect it to really be at the rpms its saying...driver input...an0malous has a how to u NEED to check out
Old Dec 22, 2007 | 10:41 PM
D4u2s0t's Avatar
it's not slippage, sounds like what anomolous said.
in simpler terms, when your wheels are spinning, the speedo shows that you are going a certain speed. but in actuality you're not. i'm just making up #'s here, but suppose the top of 2nd takes you to about 38 (that's where mine ends with 7k redline). if you're not spinning, at the top of first you will be going the 38 that the speedo reads.
but, if your tires are spinning at the top of first, the speedo may show 38, but you may be ACTUALLY going much slower.
so, basicall, what you're doing is short shifting 2nd and putting it out of it's effiency range, but expecting it to pull like it IS in the efficiency range.
how do i know this? because if you take it to the top of first, and shift to 2nd, you will be more around 4,000 rpms or so, shouldn't be anywhere near 2500. if you're at 2500 rpms when ripping through the gears, you're shifting too soon.
Old Dec 22, 2007 | 10:50 PM
srcobaltss's Avatar
alright thanks for the input. just to throw this in there..im not dumping the clutch. i'd let it out normal then wen im crusing i just stomp on it..and there i go .lol. new to the car not sure how to make it do what i want yet.. still expirementing..but i'll do as told before i have to spend 3-500 on a new clutch
Old Dec 22, 2007 | 10:51 PM
an0malous's Avatar
dont stomp it. thats 100% of your issues.
https://www.cobaltss.net/forums/show...t=driver+input
this may help
Old Dec 22, 2007 | 10:52 PM
SSdan's Avatar
Where in jersey are you...?
Old Dec 22, 2007 | 10:53 PM
Raven SS's Avatar
this may help
lol u wouldnt know how many times i link to ur **** in different threads thruout the day
Old Dec 22, 2007 | 10:54 PM
D4u2s0t's Avatar
i'm north jersey, right off of 23 and 287. not sure where the op is from.
Old Dec 22, 2007 | 11:05 PM
SSdan's Avatar
I know where you are
Old Dec 22, 2007 | 11:07 PM
D4u2s0t's Avatar
stalker!
Old Dec 22, 2007 | 11:09 PM
SSdan's Avatar
No way, just i've sent you stuff..****, I even know your work address.
Old Dec 23, 2007 | 10:07 AM
srcobaltss's Avatar
this may help
after watching your video. i went out last night and tried it. altough it wasnt perfect i felt the grab i've been wanting. now i just gotta practice my launches. thanks. if i never asked i'd be without a car AGAIN because of no clutch
Old Dec 23, 2007 | 10:54 AM
D4u2s0t's Avatar
double stalker!!
Old Dec 23, 2007 | 12:56 PM
michael1979's Avatar
isnt this the torque abuse mode that the computers are prog with????
Old Dec 23, 2007 | 12:59 PM
D4u2s0t's Avatar
no. this is trying to accelerate hard with the engine out of it's efficiency range. it's the same thing as accelerating to about 15 in 1st, shift to 2nd and floor it. you're not going to get going for a second untill the rpm's get up into the "sweet spot"
Old Dec 23, 2007 | 01:42 PM
They call me 'E''s Avatar
Driver mod ftw
Sl0wbaltSS
Nov 21, 2018 11:11 PM
Fearedbynone
Apr 14, 2016 03:25 AM
Jan 12, 2016 12:01 AM
biniecki
Oct 25, 2015 02:23 PM
riceburner
Oct 2, 2015 05:47 PM
