4 questions. Need help
Old Sep 1, 2009 | 01:44 AM
gCobalt05's Avatar
1. What is the best way to remove mudflaps?
2. How can I cut off the front bump stops without removing springs or moving struts?
3. Can I just cut the rear bump stops while spring is still on?
4. Should I get 225/40/18s? [Right now Im riding 215/35/18s]
lets hear some answers! I know you have some.
Old Sep 1, 2009 | 01:49 AM
YaKkO's Avatar
4. How sexy will 225/40/18 tires look? [Right now Im riding 215/35/18s]
Thanks guys!
okay two ?'s can be solved by manning up and removing your springs lol. Seriously it is not that hard though.
Old Sep 1, 2009 | 02:01 AM
gCobalt05's Avatar
Thing is, I just got an alignment today.
Not wanting to spend 85 dollars next week for alignment.
man up with 85 dollas for me!
How about actually answering the questions?
Old Sep 1, 2009 | 02:30 AM
question4
the side wall will be a lil bit bigger but not too much seeing how the difference is like 35 to 40
and those rims will hold 235 probably but 225 is a sweet spot and i have stock ss sc rims on 215 so when i get tires going 225 cuz 235 is pushing it on the stock rims width
answer: looks SEXY fatter tire
Old Sep 1, 2009 | 02:31 AM
YaKkO's Avatar
i did. remove em. cut bump stops done. there is no other way...
Old Sep 1, 2009 | 02:44 AM
09blackonblack's Avatar
you can fit a 245 tire in there i have them on mine
mudflap = mark with an exacto knife or razorblade while on the car take them off the car and finish cutting on the scribe you made
bumpstops... can you get to them with a sawzall? or take JUST a hacksaw blade and slip it in there... its a PITA but it should work
Old Sep 1, 2009 | 03:12 AM
BlkWdoSS's Avatar
question4
Wrong! lol, the difference is not a 35 to 40, its a change of 35% of 215 to 40% of 225
215/35R18
Section Width: 8.46 in 215 mm
Rim Diameter: 18 in 457.2 mm
Rim Width Range: 7 - 8.5 in
Overall Diameter: 23.92 in 607.56 mm
Sidewall Height: 2.96 in 75.184 mm
Radius: 11.96 in 303.78 mm
Circumference: 75.14 in 1908.5 mm
Revs per Mile: 869.5
Speed: 60 mph 100 km/h
225/40R18
Section Width: 8.85 in 225 mm
Rim Width Range: 7.5 - 9 in
Overall Diameter: 25.08 in 637.03 mm
Sidewall Height: 3.54 in 89.916 mm
Radius: 12.54 in 318.51 mm
Circumference: 78.79 in 2001.2 mm
Revs per Mile: 829.3
Speed: 57.2 mph 95.3 km/h
Speedometer Difference: 4.847% too slow
Diameter Difference: 4.63%
Any other questions about sizes try this site:
http://www.1010tires.com/tiresizecalculator.asp
l8r,
PD
Old Sep 1, 2009 | 04:42 AM
215/35R18
225/40R18
l8r,
PD
i wanted to get schooled so i left a simple yet useless answer good job on google-ing nice write up
Old Sep 1, 2009 | 09:50 PM
BlkWdoSS's Avatar
actually no google on that one lol, i keep the tire calculator bookmarked so I can adjust my HP Tuners everytime I change tire size lol
Old Sep 2, 2009 | 03:07 AM
thats something i would do
easy access
Alex47
Nov 19, 2021 08:24 AM
Turbo6
Aug 27, 2015 08:37 PM
CTCOBALTSSS
Nov 10, 2006 04:54 AM
PpAzZ1101
Mar 29, 2006 04:25 PM
