4pt harness and harness bar help
Old Dec 27, 2006 | 04:39 PM
biohazard's Avatar
Get low
i know your not supposed to ask for help in this section but theres nowhere else this fits...... i am putting in 4 pt harnesses as we speak and i have the C/A harness bar..... in the pic on their site it shows the belt wrapped around the bar but i dont see how thats supposed to work,,,,, right now i have my belts going to the back seats and bolted into the studs for the rear seatbelts.... is the harness bar supposed to have the belts wrapped around it? or just run the belts over the bar so that they go straight back and not at 30deg?
Old Dec 27, 2006 | 05:02 PM
victory_red_SS's Avatar
LSX RWD S/C conversion
I am not sure of the style of your harness connections. I know that my crossbar had tabs welded on so the belts connected just behind the seats at shoulder level.
Old Dec 27, 2006 | 05:05 PM
biohazard's Avatar
Get low
hmm i have the c/a harness bar and there are no tabs whatsoever, ts just a solid pipe looking thing
Old Dec 27, 2006 | 05:10 PM
wrapping your straps around the bar seems wrong because of the play from sliding on the bar. What are the harnesses instructions saying? Is there a diagram? (my rci's had a bad pic but it helped)
Old Dec 27, 2006 | 05:16 PM
articzap's Avatar
my friend wrapped his belts around the bar but he added another bar where he wrapped it around so the belt couldnt slide side to side. whatever you do, DO NOT link back down to the rear seat area. You can cause way more damage to yourself in an accident if you do.
Old Dec 27, 2006 | 05:34 PM
biohazard's Avatar
Get low
thats what im doing though, linking down to the rear seat but if i go over the bar then to the rear seat the belts do not come down on me, they go straight back, then down
the bar does not have instructions its from c/a if that says anything, im kinda dissapointed cuz it was all smashed up in the box when i got it and said package recieved damaged, they also charged my dads card and forgot to include shipping so cancelled his order and told him right before xmas
Old Dec 27, 2006 | 05:42 PM
But where did you get the 4point harnesses? Those should have mounting instructions.
Old Dec 27, 2006 | 05:46 PM
DWK5150's Avatar
How do the harnesses say to be mounted?
Old Dec 27, 2006 | 05:59 PM
SS/SCking's Avatar
Ya this is right... You might have to drill and tap bolth sides of the bar or weld tabs on ot it. DO NOT mount them to the floor!!! If you get in to a headon crash you'll crush your spine and that would not be cool. They should be mounted not more than 3 inchs below your shoulder line.
Old Dec 28, 2006 | 12:32 AM
articzap's Avatar
if he goes aroudn the bar and down to the floor he'd probably be alright as far as accident wise goes but i wouldnt trust it. either weld on a tab or a small hoop so that the belt is wrapped around and tightened it wont go side to side
Old Dec 28, 2006 | 12:40 AM
biohazard's Avatar
Get low
ugh this is so fking stupid then wuts the point of them selling the harness bar incomplete.... the harnesses dont tell u how to mount to a bar
Old Dec 28, 2006 | 12:51 AM
diablo2007's Avatar
ive noticed alot of their stuff is incomplete
Old Dec 28, 2006 | 12:54 AM
biohazard's Avatar
Get low
ya same here looks like this will be sitting next to my L3 fenders i bought from them that have been sitting in the basement for 10 months.... i dont have a welder and wouldnt trust doing it, plus i shouldnt have to that bar wasnt cheap (price wise)
Old Dec 28, 2006 | 01:01 AM
diablo2007's Avatar
im not really a fan of there site anymore the only reason i look over there sometimes is cause they do custom work, i lost faith in them when it took them 6 months to get my exhaust
Old Dec 28, 2006 | 01:06 AM
biohazard's Avatar
Get low
sry to vent this just sux, everything on my car had to be fukd with or modified to fit in which is cool but i want something to just go right for once, there is alwats something that goes wrong with my car when i do sht to it... the past 2 days ive been trying to drill the fking screw out of my Bpillar for my old seat belt because the tech at GM over tghtened it way to much when replacing it before, i bought a compressor and airgun still nothing, breakerbar with my 235lbs fat ass on it and wouldnt budge
Old Dec 28, 2006 | 01:14 AM
diablo2007's Avatar
just let that impact gun set on it for awhile it might come out, or maybe your impact gun isnt strong enough
Old Dec 28, 2006 | 01:15 AM
biohazard's Avatar
Get low
brought it to the dealer and they couldnt even do it.... alredy spent the last 2 days drilling/boring it out and i g2 retap it tomorrow
Old Dec 28, 2006 | 02:00 AM
TurboBlackBalt's Avatar
You can mount the harnesses to the floor as long as you have a harness bar. It is neccesary that the belt not excede more then 30 degrees up or down when it comes off the seat back. After that, you can do whatever you need to with the harness. Its actually common to run the harness over the harness bar and then down to the rear mounting points for the front seat.
Go to this site: http://saferacer.com/seha1.html
Scroll down until you see the harness installation PDF. Its everything you ever need to know.
BTW i hope you didnt buy a cheap harness. Always stick with a name brand, RCI, Simpson, G-Force, or Sparco. FIA or SFI cert always!!
Old Dec 28, 2006 | 03:06 AM
biohazard's Avatar
Get low
thanks for the help, when i go to viewe the pdf file though my browser crashes o well.... but heres where im stuck now.... where is the best spot to mount the bottem/lap belt..... i have one going to a hook where the old seatbelt used to mount (right under the door) and one under the seat, my top straps go to the back seat but its a far stretchwould i be better mounting straight to the floorboard if i drive a loop hook through it with a bolt under the car?
Old Dec 28, 2006 | 11:19 AM
articzap's Avatar
stock bolt down areas for the lap belt if you can
Old Dec 28, 2006 | 03:09 PM
articzap's Avatar
no need to weld more then that hoop ova the seat belts, ne welding shop can do that
Old Dec 28, 2006 | 11:54 PM
biohazard's Avatar
Get low
ok herers my plan..... Run the belts over the bar then down to the floor.... im going to drill 2 eyelits behind each seat into the floor and bolt it up from underneath then cover with silicone to prevent rust and sht.... the lap belt will mount to the body of the car in one part and then the inner most lap belt will mount between the seat bracket and floor
Old Dec 29, 2006 | 02:32 AM
articzap's Avatar
dude if you do it the way i showed theres no need to make holes in back floor, just goes to the bar and loops around
Old Dec 29, 2006 | 10:05 AM
biohazard's Avatar
Get low
i still dont get how their on like that....
Old Dec 29, 2006 | 10:08 AM
Sicklyscott's Avatar
take a thread and wrap it around your finger and couple times then pull real hard...what happens? Your finger turns purple... EXACTLY!!!
