60,000 mile tune up
60,000 mile tune up
Ok i just hit 60K and my dad recommended getting some things done to prolong lhe life of my car. im definately going to go and get a coolent flush but he also recommended geting a new fuel filter and replacing the trans oil (im auto). are there any more smalll tune up things that should be done? and is replacing the trans fluid nessicary because i think it says in the manual that its not nessicary to change the trans oil???
Spark plugs, air filter, cabin filter, flush brake fluid (i personally recommend doing every 30k), trans flush, (flush and filter again at 100k), check&clean throttle body. check coolant/flush (i flush every 50k). clean&adjust brake drums if u have them. fuel filter(every 20-30k.)
at my dealership we do
plugs
wires (if has)
air filter
fuel filter
oil and filter
cabin air filter
trans fluid and filter
pcv valve
rotate tires
chck brakes, service or replace if needed
inspect everything, front end, lights, leaks, etc
lube all door latches and hinges
silicone lube all weather stripping
wiper blades
i think thats it. but this is fords prepaid maint package for 100k kms
plugs
wires (if has)
air filter
fuel filter
oil and filter
cabin air filter
pcv valve
rotate tires
wiper blades
which spark plugs are best there are 3 listed.
http://www.ngksparkplugs.com/part_fi...uv/results.asp
inspect ball joints, make sure theres no tears on the axle boots, ck battery(make sure it has water filled up in holes),fuel filter, cabin air filter, ck/replace air filter(every 6-10k), Rotate tires, inspect brake pads/fluid, spark plugs/spark plug cables, flush coolant,refill windshield wiper fluid, wiper blades,thats all i can think of at the moment
im so confused on which fuel filter and spark plugs to get. im really about to just go to the dealer and get exactly what came stock.
here are the three from ngk
NGK G-PowerŽ Spark Plugs
NGK Laser IridiumŽ Spark Plugs
NGK Iridium IXŽ Spark Plugs
Im assuming the g power is the best since its platnum tip...? i read somewhere that its best for our cars
to what extent do you consider performance mods. im pretty much fully bolted, tune, header downpipe, catback, intake, throttle body... im not turbo so theres no need to go 1 step colder but i just dont know which plugs are best, i missfire everyonce and a while at high rpms on the stockers
Has anyone tried the ZZP fuel filter???
ZZPerformance - Fuel Filter for LSJ & LE5 #ZZ-FF-LSJLE5
