Aeroforce Intecepetor
Old Sep 20, 2007 | 07:17 PM
tlax23's Avatar
I just installed my Aeroforce Inteceptor. The gauge turns on fine and i have all the parameters set but it ISNT GETTING DATA from the car. It just lists what it is monitoring but no actual reading. Did I install it wrong and has this happened to anyone else? Thanks
Old Sep 20, 2007 | 07:19 PM
SS/SCking's Avatar
Is the OBDII pulged in all the way?
Old Sep 20, 2007 | 07:23 PM
tlax23's Avatar
I just checked and im pretty sure it is plugged in all the way. I bought the dual guage pod and i am using it with my stock boost guage in conjunction with it. However i didnt splice any wires when putting it in; im under the impression power comes from the OBDII port?
Old Sep 21, 2007 | 04:26 PM
Florida 76's Avatar
i heard you need to unplug the battery for like a minute.... and then it takes a day or two for them to start working propley
Old Sep 21, 2007 | 04:29 PM
an0malous's Avatar
not with these cars.
some recieve power from OBDII, but ours you have to supply power to the red wire independantly.
the OBDII has ground and data, but no power.
Old Sep 21, 2007 | 04:33 PM
tlax23's Avatar
^makes sense.
how is my guage getting power if it is not from the OBDII?
Old Sep 21, 2007 | 04:34 PM
SKDR112888's Avatar
I just tapped into the stock boost gauge power wire for the power wire =)
Old Sep 21, 2007 | 04:37 PM
an0malous's Avatar
Originally Posted by tlax23
^makes sense.
that im curious about.
i was under the impression it gets no power from the OBDII
but maybe its drawing some...but its not enough to properly power the gauge (hence your problem) and thats why we are told to give it its own power source.
Old Sep 21, 2007 | 04:40 PM
tlax23's Avatar
ahhhh that may just be it. i have driven the car twice since last night and the guage has shut off and then restarted while i was driving. (ergo lack of sufficent power)
which wire on the intecepetor should i use to tap into the red power wire on the boost guage?
RJSS's Avatar
Some people who have done it this way have had problems. Aeroforce recommends splicing a line off of the fuse box, using an add-a-fuse kit, with a 5 amp fuse. That way your gauge is getting "clean" power and can't get fried.
PS-This is the way I hooked mine up and have had no problems, and the wire is easy to hide under the dash.
Old Sep 21, 2007 | 04:42 PM
Misery5567's Avatar
He's correct.
The OBDII port is mainly used as a ground which is why you only need to tap the pink wire that goes to your factory boost gauge to supply power for the Interceptor.
I've got two in mine. They're great.
Old Sep 21, 2007 | 05:03 PM
tlax23's Avatar
is the pink wire on the Inteceptor the power wire also?
Old Sep 21, 2007 | 05:04 PM
Element2.4's Avatar
Or run it to your sunroof fuse near the passenger side seat.
Old Sep 21, 2007 | 05:11 PM
tlax23's Avatar
Once I splice the wire into a power source, which wire do splice on the guage itself to get the power to it? Can i use the adapter wire they sent me that just plugs straight into the back of the Inteceptor and splice the other end into a power source?
Old Sep 21, 2007 | 05:32 PM
Element2.4's Avatar
There should be 3 wires that plug into the back of the interceptor. If you just run the red one to the sunroof fuse you dont have to do any splicing.
Sl0wbaltSS
Nov 21, 2018 11:11 PM
SmitBag
Sep 7, 2016 08:05 AM
ineedacobaltss
Nov 7, 2015 02:25 PM
Supercharged06SS
Oct 5, 2015 09:13 PM
