Aeroforce Interceptor Guages
I tried to search for some information on these gauges, but didnt come up with much. Can someone tell me exactly what these things do. I read the C/A description but didnt help me too much. Everyone says at a certain point you need one and i really like the look of the new gauge pod Mkruley has made.
Do they show like 0-60 and similar things to that or are they just for engine status and air/fuel and timing stuff. I really dont know too much about engine computers or electric components but Im trying to learn things about it now.
http://www.aeroforcetech.com/Redline_Cobalt_tech.html
RPM
MPH
Intake Air Temperature pre intercooler
Intake Air Temperature post Intercooler *
Mass Air Flow Sensor Frequency *
Mass Air Flow Sensor (lb/min.)
Engine Coolant Temperature
Injector Pulse Width
Long Term Fuel Trim
Short Term Fuel Trim
O2 Sensor Voltage
Manifold Pressure in PSI (Boost pressure)
Supercharger Inlet Pressure *
Ignition Advance
Knock Retard *
Engine Run Time
Battery Voltage
Throttle Position Percentage
Engine Load
Instantaneous fuel economy
Horsepower
Analog input #1
Analog input #2
read the link for it all
RPM
MPH
Long Term Fuel Trim
O2 Sensor Voltage
Ignition Advance
Knock Retard *
Engine Run Time
Battery Voltage
Engine Load
Horsepower
Analog input #1
Analog input #2
they tell you almost anything about your engine and so on. I just bought one thru a group buy for like $200, and I actually recieved it in the mail today. Simple to install, plugs into your OBD2 plug, and just run power wire and ground.
Originally Posted by 1gmfanatik
Anyone know how to get the shift light to work in the Interceptor gauges?? I set the redline, but the light doesn't come on when I hit it...
That's a good question. I'm going to have to know that too. Anyone?
If you set it at the redline it won't work because you shouldn't be hitting the redline. Set it for a couple hundred below the redline that way you actually make it to that rpm and also it will give you time to react. Mine works well, I set it for 6300 I think.
Sl0wbaltSS
Nov 21, 2018 11:11 PM
