Air bag light after swapping steering wheels
So I swapped steering wheels to the SS because I wanted the cruise and everything. But when I plugged everything back in the air bag light was on. Do I need to get this reset by a tool scanner or is something else wrong, blown fuse/ loose connection? Thanks
did you make sure to put back in that little plastic piece you had to remove to get the yellow cable off the airbag?
i tried the same thing and after i took the airbag off i couldnt get the wheel off so i put everything back together but forgot to put that small plastis piece back in and my light was on. put it back in and it went away.
If it's not already fixed I did this upgrade around the same time and had no issues. I'd just recommend popping the airbag out again and re installing it (with the battery disconnected).
