Another exhaust question.
Yes I have searched some, but some topics are tough to find. Anyways, my question is seeing topics on 2.2 guys using 2.0 exhaust, is there a difference between coupe and sedan exhaust? Yes I drive a sedan, but still would like a 2.0 exhaust. No, I'm not going to try any ss badges or wings, just want the exhaust and I'm wondering if it is possible without cutting. thanks
The exhaust system would fit, but what do you mean "without cutting"? If you get a used system used from someone, it will likely be cut somewhere because you have to cut it to remove it. Removing the rear axle would be the only way to remove/install in one piece. You wouldn't have to cut anything on the car to do the swap though.
Dennis
Dennis
the stock 2.0 exhaust sucks why would you want that on your 2.2 just get a aftermarket cat-back exhaust..
edit... and yes the 2.2 coupe and 2.2 sedan have the same exhaust if thats what your asking
