Automatic ?
Old May 12, 2008 | 12:26 AM
chevyLSchik's Avatar
Automatic ?
Ok, since im automatic, im hoping some auto guys will help me. Lately my "shifter" has been sticking from D to P. Its fine going from D to N, but D to P is really hard. I feel like im gonna break it sometimes. Im not sure what the problem could be...I dont want to tear it apart and fiddle with anything yet. Anybody else having this problem?
Old May 12, 2008 | 12:27 AM
ssweeet's Avatar
Sorry, can't help you out. Hopefully someone can.
Old May 12, 2008 | 12:28 AM
Projekt's Avatar
autos suck
/end thread
Old May 12, 2008 | 12:29 AM
i hope you blow your tranny....
Old May 12, 2008 | 12:43 AM
lil_kano's Avatar
Lol. Check your fuses under the hood and on the passenger side lower air vent fuse panel.
It could aslo just be a bad shifter. I've heard about that a few times on here. has your key ever gotten stuck in the ignition?
Old May 12, 2008 | 12:45 AM
i think i have once or twice but Tom got it to "unlock" or whatever. If its a bad shifter how much is a replacement?
KillerBee's Avatar
when you put it in park does your car roll back or forward a little?
Old May 12, 2008 | 12:47 AM
i park on a hill so yea, it does until i put the E-brake on...otherwise, if im on a hill and i just let it coast to stop, and i dont put the brake on, i'll roll backwards like a manual would...
lil_kano's Avatar
I can almost gaurantee its a bad shifter or a blown fuse. The entire ignition and shifter are connected to each other.
Projekt's Avatar
i hope you blow...no one inpiticular
Old May 12, 2008 | 12:49 AM
im asking for help. if your not going to give me any, go away.
Old May 12, 2008 | 12:51 AM
Projekt's Avatar
alrighty dont take a joke..
you want some help? go take it in for warranty, best advice your gonna get on this site
Old May 12, 2008 | 12:52 AM
zackss's Avatar
a friend of mine had the same problem
but her's was because the piece of plastic in the groove where
the shifter slides up and down was popped up a little bit
she had to realign the plastic is all
just a thought
no warranty, i have 50k miles
Old May 12, 2008 | 01:00 AM
RedCobaltSS06's Avatar
Mine did the exact same thing, as everyone else said it was the shifter. There is a small button under the shifter that gets stuck or something. Sorry though, mine was warranty so I don't know the price. I'll ask my dad tomorrow. he is the service director for the dealership group in town.
Old May 12, 2008 | 02:56 AM
silverfae7's Avatar
If you take off the trim on the top of the console and look at this shifter on the pass side, you should see a little switch. There should be a bar that pushes up on that switch. It should extend about the same ammount on each side of the shifter. It gets mispositioned and causes shifter problems and keys sticking in the ignition. If you reposition it correctly, the shifter should work. It will probably get out of position again later on but it beats buying a new one.
Old May 12, 2008 | 02:58 AM
bridfi's Avatar
i have a cobalt rental thats auto. it seems i have to nearly stand on the brake pedal to get it out or into park.
just a thought.
Old May 12, 2008 | 03:03 AM
ah i'll try that
just a thought.
its never had a problem until like the past few weeks and its been getting worse...i've had it since 26k and it just broke 50k the other day
Last edited by chevyLSchik; May 12, 2008 at 03:03 AM. Reason: Automerged Doublepost
Old May 12, 2008 | 02:17 PM
shawn672's Avatar
You're not pushing the brake down hard enough.
Old May 12, 2008 | 02:31 PM
neodude101's Avatar
I also have an '05 auto LS, and my key was getting stuck about a year ago, and I took it in to get looked at and they said that it was the shifter. They replaced it under warranty. I got a new one from an '06, I believe, as my old shifter assembly had P-R-N-D-2-1 instead of P-R-N-D-I-L (I'm almost 100% positive).
Luckily enough, it was still under warranty (my car has less than half the number of miles that yours does--I just rolled over 22,000 last month). I have no idea how much it would cost to get it replaced out of pocket.
Old May 12, 2008 | 06:18 PM
i have a mechanical warranty but i dont know if it fits in that category...it only covers mechanical stuff. i might check it out.
Old May 14, 2008 | 07:17 PM
mtp082.2's Avatar
There is a service bulliten out for that problem, maybe you can get it goodwilled by a dealer. Since it is a know problem.
Old May 14, 2008 | 07:20 PM
Jimmys2007CobaltSS/C's Avatar
could be a bad shifter thats what happen to mine it wouldn't go in to park, it came to point where i had to slamed in park....and then my keys wouldn't come out . If your still under warranty you should be able to get it fixed under warranty like mine
Old May 15, 2008 | 01:33 AM
im way out of my factory warranty. i dont think my other warranty will cover it. its ok though, it looks like its just a trim peice thats buckling and not allowing it to shift properly.
Old May 15, 2008 | 01:38 AM
kkanowitz's Avatar
^^ do this...
While you're at it, see if that small metal bar is loose at all...if it is, chances are the shifter is gunna break soon. It's already happened to me and I gotta press the solenoid inside my steering column to get my key out all of the time. BTW, the part # for the shifter is 15926820. I think the dealer wanted approx. $120 + tax. GMpartsdirect.com wants $68.90. And it's easy to replace if you know how to handle basic tools.
chefhhr
Oct 26, 2015 10:36 PM
MrInsanityWolf
Sep 29, 2015 04:54 PM
Aug 29, 2015 03:11 PM
JonyyB
Jan 12, 2005 01:57 AM
