Buying used stage 2 pcm
Old Sep 25, 2008 | 10:36 PM
blackss2.0's Avatar
Hi i may purchase a pcm with a stage 2 on it from another member on here. Will this work allright?
Can i just put it on with the rest of a stage 2 without any problems???
Last edited by blackss2.0; Sep 25, 2008 at 10:55 PM. Reason: Automerged Doublepost
Old Sep 25, 2008 | 10:41 PM
Coblasts's Avatar
You change the pcm you will have to do a crank sensor relearn at the dealer .
Not a 100% but I will check it out.
Old Sep 25, 2008 | 10:54 PM
blackss2.0's Avatar
hmm. ANyone else know if i can just put in a pcm with a gm stage 2 on without any problems?
Old Sep 25, 2008 | 10:56 PM
Drakonen2000's Avatar
if you have the injectors and the pulley on already...then after you get a used stg2 pcm you WILL need a CASE learn, and a crank position sensor re-learn...the CASE learn is strictly a dealer thing! (cant really be done by a shop...you need a gm tech 2 to do it) Thing about this is, unless you tow your car to the dealer to have the CASE learn done, your timing is going to be jacked up hardcore and the car really shouldnt be driven in that condition...
Old Sep 25, 2008 | 10:58 PM
blackss2.0's Avatar
Any estimate on the cost of these relearns??
Old Sep 25, 2008 | 10:59 PM
not sure...couldnt be more than 100 bucks, i wouldnt think. But, as stated, how on earth are you going to get the car there...because there is no way it is going to get there with stg2 and no tune, or with stg2 and a different car's pcm...either way its a no go...
Old Sep 25, 2008 | 11:02 PM
blackss2.0's Avatar
does this have to be done with other aftermarket pcm's like zzp?
Old Sep 25, 2008 | 11:03 PM
im not sure about that......that would be a good question to email zoomer at zzp about
Old Sep 25, 2008 | 11:04 PM
blackss2.0's Avatar
And u can drive the car to the dealer with stock tune on stage 2. Just have to do it carefully. It says so in the how to for stage 2 install. "After stage 2 install, drive carefully to chevy and have ur ecu reflashed."
Old Sep 25, 2008 | 11:06 PM
oh ok...good to know...
but as stated...CAREFULLY!!! lol...running lean = fried pistons...nobody wants fried pistons!
Old Sep 25, 2008 | 11:44 PM
rukkee's Avatar
I drove my car to the dealer to get the flash after installing stage 2 myself . To be honest at low rpm and being easy on it , i couldn't tell a difference in the cars drivability . If you take it easy and the dealer is fairly close , i wouldn't worry about it too much.
Old Sep 26, 2008 | 10:17 AM
blackss2.0's Avatar
If i just throw in a pcm with a stage 2 on it, do i need to get the re-learns done?????
Old Sep 26, 2008 | 10:24 AM
Jackalope's Avatar
If you swap the PCM the car maaaay not work correctly. The PCM has the cars VIN# in it and changing it will show up in the BCM and may cause issues with other systems. EXAMPLE, when DOC reflashed my PCM in my 07 SS sedan he flashed it to another cars VIN# and my CEL came on. I had to have the car flashed back to stock to get the correct VIN# in the PCM so the BCM would recognize it and both computers would work together.
If you swap a computer from 1 car to another the other computers in the car see it as a problem that they have a non-matching VIN#. Like I said I know this cause I went thru it with my car. It probly won't work right.
Old Sep 26, 2008 | 10:30 AM
Bl4des's Avatar
and the tunes from zzp and other places you have to give them your vin so they can program it into the pcm
Old Sep 26, 2008 | 10:34 AM
Jackalope's Avatar
YUPPERS!
Old Sep 26, 2008 | 11:46 AM
blackss2.0's Avatar
If u buy a pcm from zzp and give them your vin do u still have to get the crank case relearn or can u just throw that in and have it work???
Old Sep 26, 2008 | 11:49 AM
Bl4des's Avatar
i think you just throw it in
Old Sep 26, 2008 | 10:50 PM
blackss2.0's Avatar
Bump. COuld this be done or not???? could i use someone elses stage 2 pcm??
Old Sep 26, 2008 | 10:59 PM
exiged's Avatar
i'm interested in this as well. I've toyed with the idea of taking a computer off a lsj and putting it on a l61, so that it would be hptuner-able. any thoughts on this?
Old Sep 26, 2008 | 11:34 PM
blackss2.0's Avatar
Last edited by blackss2.0; Sep 26, 2008 at 11:34 PM. Reason: Automerged Doublepost
ineedacobaltss
Nov 7, 2015 02:25 PM
dennis69
Oct 20, 2015 04:49 PM
OrangeCoba
Oct 1, 2015 10:00 PM
Iceberg
Sep 29, 2015 12:33 PM
Iceberg
Sep 28, 2015 01:31 PM
