a/c question
Old Feb 23, 2015 | 03:18 AM
alexway12's Avatar
a/c question
so i really didnt know what catagory to go with on this question since theres not really a section for a/c . but im looking for help with my a/c . i recently went to the store to get some r134 since my ac clutch was not engaging but i tried to fill the ac line but it was already maxed out. for some od reason the ac is not turning on and the clutch is not engaging i checked the fuses and they where good and same with r134 so is there a way to check the low pressure and high pressure switches ?
Old Feb 23, 2015 | 03:23 AM
Jesse's Avatar
Check your coolant temp while the car is running. If the coolant temp says ---* then this is the reason your AC will not work. Typically it is a code that says the coolant isn't reaching operating temps in the time it thinks it should. This can be remedied with a stock replacement thermostat or disable that code with a tuner.
Old Feb 23, 2015 | 02:29 PM
alexway12's Avatar
i checked the coolant temp today it said it was @ 176 , so is there a way to jumper the system to see if the ac even works or ? to help diagnose the problem?
Old Feb 23, 2015 | 02:53 PM
chris88z24's Avatar
Yeah, you can jump it at the relay.
If you want to DIY, I strongly suggest you buy a set of a/c gauges and the service manual for your car so you will know what the high & low side pressures will be. This will cost a few hundred so it's best to just pay your dealer 1 hour of labor to diagnose, and then fix accordingly.
Best of luck.
Old Feb 23, 2015 | 03:42 PM
alexway12's Avatar
true that , so how do i go about jumpering the relay to even see if the compressor works ?
Old Feb 27, 2015 | 03:33 AM
alexway12's Avatar
My best bet would to go to a service shop
brandon04
Oct 21, 2015 07:04 AM
patooyee
Oct 15, 2015 05:11 PM
Iceberg
Sep 29, 2015 12:33 PM
Extremespeed
Sep 29, 2015 04:34 AM
Iceberg
Sep 28, 2015 01:31 PM
