Car is burning up (engine coolant)
Old Jan 25, 2008 | 08:23 AM
celicacobalt's Avatar
Lightbulb Car is burning up (engine coolant)
For the last week or so my car has regularly been seeing about 230 degrees on the coolant temp. When it hits that high my heater does this thing where it stops blowing hot air and starts blowing cold air. I was under the impression that our coolant system was maintenance free for the 1st 100,000 miles or so.
I looked at the coolant tank and theres definately coolant in there but its not full. I didnt think it needed to be full though.
Only thing i can think of that might have happend is when i got my turbo installed the installer may have drained the coolant for installation then not put enough back in possibly. I was thinking of adding a coolant additive to help keep things cool.
maybe the stock cooling system isnt enough for the hahn turbo kit? I dont know of any aftermarket radiators for our cars though.
Does anyone have some insight on this?
Old Jan 25, 2008 | 08:25 AM
SSdan's Avatar
First off, fill the coolant.
Also, take a look at the oil please. Could never know if you blew a head gasket.
Old Jan 25, 2008 | 08:26 AM
BOOSSTED 06's Avatar
yeah you will see milky white in your oil if you blew the head gasket
G WOOD82's Avatar
From: I'm currently busy putting 10,000 kids on your mothers face!!!
well you might have vapor lock.
Old Jan 25, 2008 | 08:29 AM
spaz's Avatar
Just wondering why you would let this happen more than once? You obvisouly have a problem and hopefully you didn't ruin your engine yet.
Old Jan 25, 2008 | 08:31 AM
BoostinLSJ's Avatar
do you have any extra cooling mods to help with the heat
Old Jan 25, 2008 | 08:38 AM
Badassz69's Avatar
First thing I would check if you still have coolant in your coolant tank is to see if you coolant fans are comming on, if you just had work done on your car it's easy to forget to plug them back in, on our cars though you should set a code for it but you never know, anything can happen, if you fans are coming on and you still have coolant, and from the sound of you saying that your heater stops working it sounds like you may have an airpocket in your system which is preventing proper flow, I've seen a few of those is the cavaliers not sure if it's an issue on the balts.
2K5SS/SC?'s Avatar
Any white smoke coming from the exhaust? Fill it and if it keeps burning coolant or the oil cap looks milky, you blew a headgasket. Perfect time to upgrade to studs and a Cometic headgasket though.
Old Jan 25, 2008 | 08:39 AM
How much can i fill the coolant? is it possible to over fill the coolant? I have a tranny cooler and intercooler but thats it for anything extra to cool the heat. I'll check the oil to see if there is any white.
I let it happen more than once because I thought it may be normal for this kind of weather here since it hasnt been this cold before with me having the car.
If i blew a headgasket, how much work and money am I looking at to replace?
Last edited by celicacobalt; Jan 25, 2008 at 08:39 AM. Reason: Automerged Doublepost
Old Jan 25, 2008 | 08:43 AM
Badassz69's Avatar
I'm having the problem off my car is not warming hot enough too damn cold, think my thermostat is stuck open, it's around 30's to 40 high's here if we are lucky lately and I'm not getting hotter then 185 even if I let it sit there and idle for half an hour, I've been doing that cause my battery keeps discharging cause my commute is only 5 mins now.
do you have any codes or it running rough, if you totally blew a head gasket you should be missfiring and all kinds of driveablity concerns, not just it running hot, unless its a small leak.
Old Jan 25, 2008 | 08:46 AM
Co|3aLt $$'s Avatar
my car only gets to like 192.... never went any higher unless I really get on it or sit it traffic on a hot day...what temp does yours get to normally?
Old Jan 25, 2008 | 08:48 AM
Badassz69's Avatar
You can overfill your coolant cuase when it gets hot the fluids have to expand a bit, the cap will release the pressure if it gets too high though and vent coolant, I would not fill it up past 3/4 of the way, it should say on the bottle fill to here when cold.
Old Jan 25, 2008 | 09:25 AM
TheSilentFart's Avatar
Subscribed.
Old Jan 25, 2008 | 04:05 PM
temps that i normally get to and cause me no conern is about 210 tops. so when its getting to temps like 220.226, 228. thats where my concern is. car has no drivability problems though. Ill check the oil and coolant level when i get out of work today at 2.
looks like the coolant could use a top off cuz its not up to the line its about an inch lower than the line. hopefully a refill will do the thing. We use dex-cool right? also, since im turboed i think im gonna put an additive in there from whatever company has their product at pep boys.
Last edited by celicacobalt; Jan 25, 2008 at 04:05 PM. Reason: Automerged Doublepost
Old Jan 25, 2008 | 04:10 PM
redlineblueline's Avatar
could it be a thermostat stuck closed
Old Jan 25, 2008 | 04:57 PM
Area47's Avatar
Rent me! per hour
pop goes the head gasket
Old Jan 25, 2008 | 05:11 PM
rallyracer's Avatar
Where can we get a cometic headgasket and what studs are you talking about??
Old Jan 25, 2008 | 05:17 PM
SSdan's Avatar
Please read the 2.0L section.
Old Jan 25, 2008 | 05:33 PM
Zdeuce4's Avatar
do u see any coolant on the ground when u move the car? if so could be a freezer plug...
Old Jan 25, 2008 | 05:38 PM
Area47's Avatar
Rent me! per hour
my freezer doesn't have any plugs
nramlow2006's Avatar
yeah.. but i though boats only had freeze plugs.
Old Jan 25, 2008 | 05:50 PM
Area47's Avatar
Rent me! per hour
negative ghostrider
Old Jan 25, 2008 | 06:04 PM
SSdan's Avatar
roffle.
Blocks have freezer plugs too!
Old Jan 25, 2008 | 06:32 PM
SS4ME's Avatar
I think I'm in the same boat as you. My cars temp. skyrocketed to 232 a week ago. All of a sudden I'm showing a low coolant signal on the the digital display. I checked my oil cap and sure enough it is full of yellowish froth! Bye bye headgasket!! I have an appointment Monday but needless to say it is a sad day for me and my balt. My car is stock also! Time to trade it in for a Honda!
Old Jan 25, 2008 | 07:53 PM
well, my oil looks fine. I bought a container of dex-cool and a bottle of redline water wetter.
Is there a how to on draining the coolant since I have never done this before?
What concentration should I use in my freezing temps here in Pittsburgh with the water wetter and dexcool?
no coolant on the ground for me. perfectly dry under my car. no weird smells and no coolant lights are even on yet. I dont know what temp the light would turn on at but it never has turned on, im just going by my own judgment that the temps are too high without the light saying anything.
Last edited by celicacobalt; Jan 25, 2008 at 07:53 PM. Reason: Automerged Doublepost
