Car shaking alittle at 60.
I have noticed lately that at around 60 mph the steering wheel will shake. When i hit about 70 its fine again. Im not sure if its the speed or if its 4th gear thats making it shake. I cant really remember if this was alwasys happening either. Have only had car a few months, so its not that old. Allignment is fine, and the tires should be balanced ok. Anyone else ever have this problem?
if your tires balance is ok then you may have a bad tire, or a bent wheel but if it was either of those you would most likely get vibration all of the time. i would take it somewhere have them spin them on the balancer and make sure they check for any seperation or any bent wheels.
Yea, its weird that it really only happens at exactly 60 mph, then stops. Dont really think its the allignment, cause the car stays straight if i let the wheel go. Only thing I did was take off the driver side front tire to put my intake in. Probaly just have them look at it when I bring it in for an oil change next time.
just a thought
I have the same issue with my car. However its only noticeable on my low pro 17's. With my stock 15's its fine. I have had everything checked at the dealership and the only thing they could find wrong was the brakes were wearing on the rotors a little uneven and said that the rotors could be the problem that when i needed new pads to change the rotors out and see if it fixed the problem.
yea. if you don't know how to check for that, the easy way is to pop your hood, step on the brake and give the car a LITTLE gas. if the engine looks like it wants to jump out of the car, probbly a broken mount. this is obviously not very good for your car, so you don'[t want to sit there for 5 minutes with your foot on the brake and give it gas.
i have the exact same problem though and only at 60pmh
your joke didn't sound like a joke, and i thought i was seriously answering a question.
thank goodness i don't have a balt' or i'd be worried
that was about the Flintstone comment...
that part was a joke..
saying that i have the same problem wasn't a joke...
mental note.. from now on if i'm just kidding make a huge sign saying HEY GUYS I'M JK DON'T FLAME PLZ!!!
