Car surges/ bucking hard when accelerating
Old Feb 7, 2021 | 01:10 AM
Trashycobalt's Avatar
Car surges/ jerking hard when accelerating
Hi i have a 2007 cobalt ss sc completely stock other than a catless down pipe, when im driving and give about more than 25% throttle in any gear it bucks/surges badly untill it gets to about 3800-4200 rpm and smooths out but if i putt around with not much throttle its fine, even revving it out. At idle it also seems a little off. Ive changed spark plugs twice, cleaned the throttle body, replaced the fuel filter, replaced the maf and the pre cat o2 sensor, tested the fuel pump pressure, compression and smoke tested for vacuum leaks. No codes are present. I used misfire monitor and it is indeed missing at idle and when accelerating not like a granny, misfire is not specific to any cylinder its all over the place. Has anyone else ever ran into this issue and figured it out? Any advice is appreciated, thanks!
Old Feb 7, 2021 | 08:36 AM
Raven2k's Avatar
Perhaps it has something to do with the injectors?
Old Feb 7, 2021 | 12:55 PM
I thought maybe but since all the cylinders are misfiring i think its unlikely.
Old Feb 7, 2021 | 01:38 PM
BlackielawlessSS's Avatar
Coil packs? I had that happen with a 02 Mustang GT 4.6.
Old Feb 7, 2021 | 01:44 PM
Raven2k's Avatar
yeah, true. Most likely coil packs. Or harness which is unlikely.
Old Feb 7, 2021 | 03:07 PM
I had previously had the 4 coil packs switched out with ones from a good running car, also tested the wiring. But like with the injectors i find it unlikely all cylinders miss at random and only between takeoff to 4000 rpm with anything more than quarter throttle and no codes
Adam Dill Reid
Sep 29, 2020 10:40 AM
BEnSonn
Feb 25, 2018 10:40 AM
califcarm
Nov 6, 2017 10:49 AM
BowtieBoi
Jan 28, 2014 07:19 PM
vinalhaven15
Sep 8, 2012 08:45 PM
