Case re-learn and crank sensor position re-learn need help asap
Old Sep 25, 2008 | 11:14 PM
blackss2.0's Avatar
IM thinking about buying a pcm from a member on here that has a stage 2 on it to use with the rest of the stage 2 parts i have sitting in the garage. A member said that if i were to install this i would need a case re-learn and crank sensor position re-learn. Is this true? And with other canned tunes does this need to be done as well??
help
Really need an answer if anyone knows.
bump bump bump
Last edited by blackss2.0; Sep 25, 2008 at 11:14 PM. Reason: Automerged Doublepost
Old Sep 26, 2008 | 03:18 AM
maverick0716's Avatar
Yes, it needs to be done because the PCM needs to be setup for your specific engine. The crank sensor position relearn is the CASE learn......same thing. I did mine with my MSD Dashhawk, so if you know anyone with one, it will work. I believe and Interceptor gauge can do the same thing.
Sl0wbaltSS
Nov 21, 2018 11:11 PM
Tupp
2.2L LAP Performance Tech
Jan 2, 2016 12:04 PM
Stuff
Oct 1, 2015 05:47 PM
cw383
Sep 30, 2015 12:41 AM
jmelton327
Sep 26, 2015 10:04 PM
