changed supercharger pulley
Old Dec 30, 2007 | 01:17 PM
frdmustang92's Avatar
changed pulley today went from stock to 3.10 put ngk iridium 1 step colder plugs and i gained 1.5 lbs of boost and it gets there alot quicker next mod is cold air induction and ingalls torque damper.
Old Dec 30, 2007 | 01:18 PM
JPizzle's Avatar
Sweet!
Put a Stage 2 on it & you'll be flyin high!
Old Dec 30, 2007 | 01:20 PM
Coblt ss super's Avatar
i had the same set up at one point, it was great, but throw some injectors and go smaller and youll have fun
Old Dec 30, 2007 | 01:29 PM
Onyxd04Redline's Avatar
You need more FUEL
Old Dec 30, 2007 | 01:30 PM
kenhebe's Avatar
That's one LEAN machine.
Old Dec 30, 2007 | 01:41 PM
srowler9's Avatar
more fuel is now needed. you will be running lean. Also, those plugs are pointless with your mods.
Old Dec 30, 2007 | 01:42 PM
kenhebe's Avatar
Stage 2, with exhaust, 1 step colder plugs and a lightweight 2.9 pulley is a good safe set-up. I go from 0-15lbs of boost instantly and then it climbs from there.
Old Dec 30, 2007 | 01:47 PM
Don't waste your money on S2
HPT
TM removed
60lb injectors
2.8" pulley
ENJOY
Old Dec 30, 2007 | 01:49 PM
kenhebe's Avatar
I'm talking about a safe set-up that if you want to revert it back to a stock stage 2 set-up for warranty reasons easily. If you don't care, then 60's a tune a 2.8 etc is definately the way to go.
Old Dec 30, 2007 | 02:25 PM
i shoudnt run lean only gaining 1.5 lbs
Old Dec 30, 2007 | 02:26 PM
The stock injectors are ****. I'm sure you're very close to running static.
Old Dec 30, 2007 | 02:29 PM
in the futer im going to get a 2.9 pulley 42.5 injectors and a hp tuner. are the tuners user friendly never ued one before
Old Dec 30, 2007 | 02:34 PM
Get 60's because you'll want to run a 2.8". Also should have someone tune your car that has done it before.
Old Dec 30, 2007 | 03:59 PM
srowler9's Avatar
There is 2 reasons to get the stage 2..
1- if you like keeping your warranty (which i have 98,000 miles left on the power train)
2- you don't have any experience with custom tuning. Unless you know someone that has experience, don't bother.
So if you do, then do what the other guys said
Old Dec 30, 2007 | 06:06 PM
is the stage 2 a 2.90 pulley? my factory warr. runs out soon but i bought an extended warr. with a 6 year 75000 mile i have my own auto repair shop so i do all of my own repairs.
does a stage 2 give good power increase
Old Dec 31, 2007 | 07:10 PM
kenhebe's Avatar
The stage 2 kit makes it a completely different car. Quite honestly it is the way they should have sold the car to begin with.
Old Jan 1, 2008 | 12:49 AM
rukkee's Avatar
I would throw a tune and some injector's at it sooner than later. You're pushing it , especially with our air temps below 0 F, and lower elevation .
brandon04
Oct 21, 2015 07:04 AM
Oct 20, 2015 09:56 PM
SSLOW06
Oct 1, 2015 07:21 PM
patooyee
Oct 1, 2015 01:07 PM
z28addiction
Sep 28, 2015 12:03 AM
