Cleaning interior plastic
The California Car Dash Duster does a great job. If you want an actual chemical product, 303 Aerospace Protectant is awesome. It's pricey but it also does leather, tires, and all exterior rubber/plastic trim as well.
Originally Posted by DanM
What are you guys using to clean the black interior plastic? It's kinda odd stuff to clean ... odd texture. Anyone discovered any cool products?
I use Meguiars vinyl and rubber protectant. Works pretty good so far. Help's smooth the texture a little so that it doesn't scratch so much. :-)
Meguiars just came out with some new interior protectant in their NXT line of products (great stuff), its called "NXT Tech Protectant". I've used it a couple times, and I was impressed. Works much better than ArmourAll, and it even smells great.
Its also not as greasy as ArmourAll, which is a big plus. Once you put it on the surface and wipe, it absorbs into the dash - so when you touch it afterwards, there's no greasy/oily resedue left on your skin.
If you want a loss-gloss look, give the Meguiars Quik Interior Detailer a try. You can spray it on any surface of your interior, including metal and glass, and it leaves it with a clean, "natural" shine.
I like Meguiars ****... how's the gloss on that stuff? I'm trying to find something that doesn't gloss up the dash too much.
With a single application it's a low gloss look, the more you put on the more gloss you add. :-)
