Cleaning the rotors?
Old Jun 12, 2006 | 07:30 PM
mkulrey13's Avatar
Mine are rusted and look ungly with my new rims. How can i clean them up?
Old Jun 12, 2006 | 08:33 PM
DTM2188's Avatar
I'd like to know too. So bump.
Old Jun 12, 2006 | 08:42 PM
laserblue2006's Avatar
the rust just happens when the rotors get wet.....if you go drive and use the brakes then the rust should wear off fairly qickly if not then you have a bigger issue...
Old Jun 12, 2006 | 09:45 PM
NiceBaltSS's Avatar
Yea i had this problem when i got my new rims and painted my calipers i realized it! I just washed them when i washed my car and then drive the car, the rusty part will just dissapear!
Old Jun 12, 2006 | 10:09 PM
mkulrey13's Avatar
Well its not the part where i brake. its like around that area i guessu its rusty
Old Jun 13, 2006 | 06:19 AM
uthinkimodd's Avatar
I'm pretty sure there's a thread on this in the how to section but i'm not gonna search for you. it may not be for painting the rotors but would be for the calipers you could probally use the same steps to paint your rotors though.
if it was me i'd just take them off give them a wire brush treatment then throw some rustoleum primer and maybe some heaavy duty paint on the they should be good to go.
Old Jun 13, 2006 | 09:09 AM
DARK AGE 53's Avatar
removing the rotors to paint them is a good idea but you want to use a high temp paint ( caliper paint ) not rustoleum paint, if you can't/don't remove the rotors you can always just mask off the area you don't want painted ( brake pad contact area ) and do it that way.
Old Jun 13, 2006 | 11:32 AM
StreetDreamz's Avatar
Black spray paint. Don't worry about it getting on the rotor surface. It will wear away the first time the brakes turn and will not affect pad longevity/action.
Old Jun 13, 2006 | 11:34 AM
player_1's Avatar
don't worry about it, you'll have to change the rotors soon enough anyways den get a set of powerslots and all will be good
Supercharged06SS
Dec 11, 2022 04:47 PM
Jan 12, 2016 12:01 AM
Oct 20, 2015 09:56 PM
DANRICKARD
Oct 1, 2015 12:08 AM
grampss
Sep 27, 2015 08:51 PM
