Clear third light?
Old Nov 10, 2012 | 05:05 PM
blackjack232's Avatar
Clear third light?
Does anyone sell just the lenses? Or would I need to Retro a thing of plexi?
Old Nov 10, 2012 | 05:24 PM
serega12's Avatar
Nobody sells them IIRC. What color is your 'balt? why not smoke it out? Then put an LED strip or two behind it for brighter bulbs..
Old Nov 10, 2012 | 06:27 PM
sLAsh's Avatar
You would have to make your own. Here's a how to
How to cast auto car parts - tail light
Old Nov 11, 2012 | 12:42 AM
serega12's Avatar
Thumbs up
Seems like a great how-to. Might need that one day.
Old Nov 11, 2012 | 09:16 AM
z062007vette's Avatar
Sub'd if you make one. And to keep this around for if I ever wanna do it.
Old Nov 11, 2012 | 09:37 AM
StevoElSupremo's Avatar
clear lenses would look killer on a silver or white car!
Old Nov 11, 2012 | 10:31 AM
Ditto. Might do it. Need that thing call "time" though.
Old Nov 11, 2012 | 10:59 AM
well, it`s like this. with the G% coupe trunk i bought there isn`t any reverse lights, so using a Clear third brake light you can make it `legal` again. so i need to manu. one then.
Old Nov 12, 2012 | 02:41 PM
serega12's Avatar
Thumbs up
This is how you get around that: HIGH POWER 18W LED BACK-UP LIGHT LICENSE PLATE FRAME
And here's a video.
Problem solved..
Old Nov 12, 2012 | 02:44 PM
id love to do that one day for my 3rd lense and side markers to complete the k2 look
will i actually do it though... probably not
Last edited by riceburner; Nov 12, 2012 at 02:44 PM. Reason: Automerged Doublepost
Old Nov 12, 2012 | 03:48 PM
sLAsh's Avatar
This is why I saved the link. You can make a board with a number of red LEDs to keep the third brake light legal and put in some high power white LEDs to run as reverse lights.
Old Nov 12, 2012 | 04:11 PM
SSCOBALTSS07's Avatar
And here's a video.
V-LEDS LPF Backup Lighting System - YouTube
Problem solved..
that would be perfect for the g5 trunk conversion
Old Nov 12, 2012 | 08:08 PM
serega12's Avatar
For that I used this:
Dupli-Color SHD1000 Shadow Chrome Black-out Coating Kit : Amazon.com : Automotive Dupli-Color SHD1000 Shadow Chrome Black-out Coating Kit : Amazon.com : Automotive
My idea behind it was, if you can see original chrome through it, you should be able to see original light though it better than through niteshade or whatnot (which is an actual blackout) with some smoke effect. Loved the end result:
Old Nov 12, 2012 | 08:11 PM
serega12's Avatar
That was one of my options for european conversion on my old Focus. In eruope they have separate backup lights in the bumper, so the regular backup light would be deleted if I went with european tails.
Either way, I was going to go with license plate frame LEDs or switchbacks (amber for turn signal, wire up white to work as backup lights)
Old Nov 12, 2012 | 08:13 PM
occsdude's Avatar
i have these same tails, i wouldnt mind having a clear 3rd break light then night shading it some since i have an impala led 3rd tail
serega12's Avatar
Integrate LED ring from K2 lights for the tail/turn signal, replace regular 3157 with 3057 white LED for backup. (that's if your lens will be clear)
You have to think of a way to integrate a red reflector to keep it truly legal. And use the clear coat with some UV protection to help with yellowing problem most clear aftermarket lights suffer from.
Old Nov 12, 2012 | 08:15 PM
serega12's Avatar
I just smoked mine with some leftover niteshade. Eventually I'll strip/sand it and respray with the chrome blackout/smoke spray. I like the result better (still black, way more transparent when lit). I do have two 12" SMD LED strips behind there, so they still shine through quite well.
Old Nov 12, 2012 | 08:23 PM
occsdude's Avatar
i want grey plastic like the tails
Old Nov 12, 2012 | 08:31 PM
serega12's Avatar
Thumbs up
Yeah, then starting with clear would work better than red then...
I'd still use the Chrome blackout stuff... It does look smoked in person as opposed to blacked out.
Old Nov 12, 2012 | 09:01 PM
LamboW9's Avatar
I did mine, this is installed but I am not finished yet, i've designed a way to hide the green board that without smoking or impairing the LEDS but haven't got to it yet. been busy with other things on the car.
also, this is for the third brake light, not for yall to bash on how much you hate my wing. i like it so GTFO. (just heading ppl off at the pass here)
Old Nov 12, 2012 | 09:31 PM
occsdude's Avatar
what did you make the 3rd tail out of?
Old Nov 12, 2012 | 09:37 PM
LamboW9's Avatar
its cut plexiglass. overlapped on the inner side of the trunk pressed snug up against the hole and then screwed fast. siliconed all around the plexiglass to ensure it doesn't leak. but since its all done on the inside you can't tell.
Old Nov 12, 2012 | 09:39 PM
TommyP's Avatar
AWD > FWD
I would "assume" th as t he made it using a home made vacuum forming table
Old Nov 12, 2012 | 09:40 PM
occsdude's Avatar
not sure id want to do that, i think ill see if i can mod the stock plastic lens and see if i can use the stock mounting tabs/arms and epoxy plexiglass to them
Old Nov 12, 2012 | 09:42 PM
TommyP's Avatar
AWD > FWD
Oh didnt see that post. You guys should really look into making a vacuum forming table. It can be done pretty cheaply, and you can make a lot of cool stuff
