Clutch Questions
Clutch Questions
So i have a 2005 G85 cobalt ss stage 3 266whp/244wtq. i had bought a spec stage 3 clutch to replace the one i have now as it is slipping. but after hearing bad things about it i decided to return it and go a different route. I have not yet decided what to get but i really want a clutch kit that can hold at least 400hp/tq at the wheels but is not to expensive. looking to spend 500-600 tops. what do you think i should get. and has anyone else on here heard or know of spec clutches on cobalts not performing well? zzp told me they had one break on them on the dyno...what type of clutch do you guys think i should get?
go with the upgraded LSJ GMPP clutch from crate engine depot, get all your bolts, and alignment tool and then go to zzp and get the flywheel. much cheaper from them then it is from crate engine depot.
use the search for the forum man. idk how many times this has been covered. go to google and type "best clutch for lsj cobaltss.net" then boom all your answers come up lol.
its to late thought. I am a brand new cobalt owner. when i bought the car it needed a clutch. i knew almost nothing about cobalts or clutches eaither but i def just wanted to get something that would hold under alot of power. i am putting a custom supercharger on the car that will make around 400 HP and can make alot more with a smaller pulley and injectors. that is why i got the spec stage 3...before i had it installed i heard a bunch of bad things so i sent it back but i have not heard anything bad about the flywheel so i kept it.
Well now that we know your future mod plans, we may have suggested a different clutch to use. A lot of people swear by different clutches, and at the same time other have had nothing but issues with clutches people swear by. Really your main choices are Spec, KY, and Southbend. I've heard good and bad about all three just reading around here, but KY and Southbend seem to be the most popular choices. If you plan on making this your DD you might want to look into a full faced disk, as the combo of the aluminum flywheel and a pucked disk might make a daily driver a bit intolerable, especially if you get stuck in a lot of stop and go traffic.
ok. i have heard of people using the gmpp kit up to 500 hp. is that true? and why does the flywheel affect the way the car drives?...zzp reccomends i use south bend....but they also told me it was take about 12k in mods to get to 400hp.
As to the amount for mods, I don't know much about the supercharged LSJ's, but from my understanding with your power goals a turbo swap would probably be more economical from a financial standpoint.
exactly what they said about the flywheel
you want 400hp in an lsj your not gonna spend 12K but youll spend a decent amount for a turbo swap or a TVS 1320 with all supporting mods and e85
did you buy that supercharger from a guy in harrisburg pa??
reason i ask is i know the kid who had the car and supercharger before you and i have lots of information for you if you would like it lol.
was his name sam? my email is lewisisaac91@gmail.com i would prefer to take this conversation there. and yes. i live in harrisburg pa.
