Clutch replacement, need clarification.
I just got my Stage 3 KY Clutch, came with a TOB.
OEM Flywheel with flywheel bolts are ordered.
Pressure plate bolts, do I have to replace these? If so, how many do I need?
Clutch pipe, do I have to replace this?
Axle nuts? If so how many?
Thanks.
Thanks.
part numbers for verification
axlenuts
Axle Nut LSJ, LNF 10289657
pressure plate bolts
LSJ Pressure Plate Bolt 90470712
Cobalt Clutch Pipe
Cobalt Clutch Pipe 24422067
axlenuts
Cobalt Clutch Pipe
Technically you don't have to remove the axles from the hubs to remove the trans.
You can just pop the pass side off of the intermediate shaft, pop the driver's side out of the trans and turn the knuckles so they face the rear of the car.
