Cobalt Front End Clunk
Old Oct 1, 2013 | 08:40 PM
Jp Freak's Avatar
Question Cobalt Front End Clunk
I've done a bunch of searching on this problem, but cant find exactly what I need.
I have a 2007 Sedan LS with a loud clunk in the driver's side front end when I hit any type of bump. I also have a small clunk coming from the same location when I feather the pedal at high way speeds.
I've replaced the sway bar end links and the control arm bushings. everything else seems to be in good condition, but I'm still getting the noise. I have no idea where its coming from!
TIA!!
Old Oct 1, 2013 | 09:50 PM
Pinky Demon's Avatar
Possibly rubber strut mount bushings? In all honesty though, it's a Cobalt. I don't think I've ever heard a quiet one.
Old Oct 1, 2013 | 09:54 PM
LNFTX's Avatar
Strut mounts
Steering intermediate shaft
Axle shaft/end play
Old Oct 1, 2013 | 09:55 PM
Or loose swaybar endlink, or the CABs are shot again, OEM CABs are not exactly the best design
Old Oct 1, 2013 | 10:02 PM
Powell Race Parts's Avatar
what did you torque the cab bolts to? the spec is 75 ft lbs plus 180 degrees = 145 ft lbs.
did you do that?
wondering
Old Oct 1, 2013 | 10:28 PM
Jp Freak's Avatar
Just replaced the CABs last week with moog replacements. Torqued everything to specs. And just recheck torques tonight.
Axle shafts have no "in/out" play. Struts seem ok. What's a good way to check them?
Old Oct 1, 2013 | 10:50 PM
rubber cabs are just that. i would check ur top bearing on the strut. what springs are on it. need the whole story lol
double clutch's Avatar
Check your steering column. Put ur key in the ignition and turn the key to unlock u wheel but dont start ur car. Shake the wheel back and forth and listen for the noise. If not that i would think stuts. On my trans am they would clunk over any small bump. Is it just a clunk or rattling?
Old Oct 1, 2013 | 10:51 PM
its an LS . Your sway bar bushings are shot I expect and single bolt and tab fixing for the bushing is fail for sure. update/upgrade.
https://www.cobaltss.net/forums/gene...6/index25.html
check this link
Old Oct 2, 2013 | 12:28 PM
Jp Freak's Avatar
sway bar bushings seem solid and I can get any play out of them. I removed the end links and it still makes noise. End links were just replaced also, and they are also torqued to specs which I believe is 50ft/lbs.
Suspension is all stock. However I was playing around with the idea of lowering it.
If I turn the wheel with the car off, it makes a small clunk when I turn it side to side. Not sure it that's the same clunk just magnified when going over bumps?
I'm about ready to just give up with it lol. It doesn't seem to be hurting anything, just annoying.
Old Oct 2, 2013 | 12:31 PM
Drunkship's Avatar
I'm in the same boat. I think the clunking when you turn the wheel is the intermediate steering shaft.
Old Oct 2, 2013 | 12:59 PM
There is a TSB on clunks. It's many pages long. It's on here. Google can find it
Old Oct 2, 2013 | 01:44 PM
the clunking noise when u turn ur wheel is ur intermediate shaft. Either replace that or buy a whole new column. Mine did that too but i replaced all my suspension and it quieted it up from the smoother ride
Old Oct 3, 2013 | 03:21 PM
Chevrolet Cust Svc's Avatar
Hi JP
Would you like for me to look up your VIN to see if there is a recall for this issue? If so please send me your VIN and current mileage by private message.
Jackie
Chevrolet Customer Care
Meadowvalien
Aug 17, 2017 06:32 PM
Albertsstc09
Sep 16, 2015 08:18 AM
Sean Cummings
Sep 11, 2015 09:35 PM
Josh@ottp
Sep 5, 2015 07:46 PM
