coolant temperature to worries??
Old Sep 21, 2007 | 10:52 AM
Pickles's Avatar
The temperature at which the fans come on can be changed with hptuners... Since I got mine, the fans come on at 90 degrees celcius, and bring it back down to about 80-83, depending on the temp outside...
Old Sep 21, 2007 | 10:59 AM
WunSick's Avatar
Great read, awesome work Tomtwtwtw that was really informative i feel better bout my 210-120 in hot ass traffic
Old Sep 21, 2007 | 11:03 AM
skymynx's Avatar
you can also have a custum tune done. my tune is set to turn the fans on and the intercooler pump the second i turn the ignition on. im at 185 crusing, and 98-102 iat2s. dont be concerned bout 230 if ur sitting. if gets much hotter or its 230 all the time then i would be worried. till then your fine.
Old Sep 21, 2007 | 11:23 AM
WunSick's Avatar
i mgiht drop my fan turnon 10 degrees when i get my tune, i gotta make a list of all the **** thats gotta change, good lord...
Old Sep 21, 2007 | 01:08 PM
rukkee's Avatar
Turn your defroster on and hit the A/C button .... fans will come on . I do that when i see it at 212f or over . I believe the car starts to pull timing at 212 .
Old Sep 21, 2007 | 01:11 PM
an0malous's Avatar
i was just about to say the AC too.
AC forces your fans on. and will cool her off.
and no you cant really FEEL your fans....but unless your deaf...you can definately hear them
Old Sep 22, 2007 | 01:35 AM
My06Kobalt's Avatar
my highest is 212 in the dead summer traffic
Old Sep 22, 2007 | 01:37 AM
KillerBee's Avatar
Originally Posted by Tomtwtwtw
You can go to 260+ before the coolant starts to boil. At that point, it turns into steam and loses the ability to keep the car cool.
there is something wrong if your temp is 260
Old Sep 22, 2007 | 01:44 AM
My06Kobalt's Avatar
agreed
Old Sep 22, 2007 | 04:39 AM
HunterKiller89's Avatar
Originally Posted by CobaltSS-Superchager
What is the highest temp of coolant before over heat.. Because when i was stuck at HIN my temperature gauge hit 230 so i crank up the heater and temp. slowly drop until i can get a parking space..Was a little worries.. I check my manual, no temperature danger is indicated... my avg is 185
turn on the A/C and recirculate the air, turn the fan to its lowest speed that its on, the 2nd setting
running the a/c and recirculating the air turns the cooling fans on their highest speed
Old Apr 25, 2016 | 10:34 PM
  #36
Bullfrog59's Avatar
You're fine. I've topped 230 once or twice sitting in traffic or coming off the freeway. Your fans will kick on and bring you back to normal. If it got hot enough to be of danger, your car would ding at you, and *then* you may want to fire up the heater or turn the car off.
That should never happen though unless you spring a leak somewhere. A leak, even if no liquid comes out, causes the system to lose pressure and the coolant will boil at a lower temp.
Yours fans will help but they when the engine is cooking water like that you need to check your water pump, your probably thinking " well wouldn't my coolant just keep getting hotter " and yes it would if it didn't work, but 60% of the water pumps from factory come wired wrong, and these pumps are dual polarity, which means they can flow either way, which can hugely affect your water temp if coolant is flowing the opposite direction. I was racing someone today and my coolant touches 192 for the first time ever, so if your in the 220 range, you need to check it out
Old Apr 25, 2016 | 10:38 PM
  #37
cluelessk's Avatar
Welcome to the site.
But you just bumped a thread that's almost a decade old....
brandon04
Oct 21, 2015 07:04 AM
patooyee
Oct 15, 2015 05:11 PM
grampss
Sep 27, 2015 08:51 PM
riceburner
Sep 26, 2015 12:57 AM
