Cruise Control?
Old Jul 12, 2006 | 12:43 AM
HellHound's Avatar
Cruise Control?
So I drove my SS/SC to MD last weekend from NC (8 hr drive) and on the way back my Cruise Control took a **** on me. Seems the toggle button went bad and needs to be replaced. it kinda wiggles in there if ya' know what I mean. Anyone else have this problem?
Old Jul 12, 2006 | 01:37 AM
cobaltsslvr's Avatar
it happened to me to like 1 month ago drove like 2000 miles without it!!! my dealership is backed up so i have to set an appt. to have it fixed. dont know what the problem is will check back here to see if anyone knows a fix. fwiw mine is a 2005 one of the first ones built.
Old Jul 12, 2006 | 01:44 AM
HellHound's Avatar
Mine is an 06' with just over 6,200 miles. I'm not goin to complain cause this is the first problem ans it's not major. Dealer ordered the part and I glad it's warrenty. just a lil' over $100!!
Old Jul 12, 2006 | 01:52 AM
Casey J's Avatar
yea I have an 06 and mine was working fine and i used it on my vacation about a week ago on the way to the beach and everything was ok and on the way back five days later it went out. Im getting it looked at soon will reply.
Old Jul 12, 2006 | 09:15 AM
Allshot's Avatar
Mine just stopped working last night. Also when putting the car in reverse does anyones car idle real bad like the rpm's drop then go to normal. It does this like 3 times then its fine My car only has 2k miles too.
Old Jul 12, 2006 | 09:23 AM
Mrmaasta's Avatar
My Cruise control button is more wiggley than the others, but I have had no problems with mine. Interesting.
Old Jul 12, 2006 | 09:28 AM
Allshot's Avatar
No one is having the "REVERSE" issue.
Old Jul 12, 2006 | 09:51 AM
firesting's Avatar
I think the reverse idle and even just starting up idle dropping and them back to normal only happened to me like once or twice, but seems to be fine now. As for the cruise control, I went to Ottawa (From Montreal; About 200 km's one-way) two weekends in a row and used my cruise all the time, works fine. But, I do notice that my cruise on/off button on the left is loose, but still works great.
Old Jul 12, 2006 | 10:08 AM
IMADreamer's Avatar
This will sound dumb but is it possible that you maybe almost stalled the car? The other day I was backing out of the driveway at my parents house which is on a steep hill and I didn't give it enough gas. Instead of letting the car die I clutched it really quick and stop for a second. The revs dropped to almost nothing then shot up to about 2k and repeated that a couple of more times then all was well and I drove off as normal. It seemed to me that almost stalling the car caused the computer to overcompensate a few times and it took it a second or two to get it's bearings again.
Old Jul 12, 2006 | 11:37 AM
joeytroy's Avatar
HellHound,
You might want to take it in, here was the problem with mine
https://www.cobaltss.net/forums/problems-service-maintenance-69/cruise-control-wont-engage-fyi-24997/
Old Jul 12, 2006 | 11:40 AM
RaineMan's Avatar
My cruise took a crap on me twice in my 2.4... fixed both times under warranty.
Old Jul 12, 2006 | 01:58 PM
Allshot's Avatar
It only happens when i drive for like 20 minutes then i pull in reverse in to my garage. I have the clutch fully pressed down and the rpm's go low then they go back up about three times then its good.
Old Jul 12, 2006 | 02:00 PM
Allshot's Avatar
And this is not happening because of the upgrades. This was also happening at stock.
Old Jul 12, 2006 | 08:48 PM
HellHound's Avatar
Originally Posted by joeytroy
HellHound,
https://www.cobaltss.net/forums/showthread.php?t=24997
I took it in and all they found was a bad switch, no codes. I guess time will tell!
Old Jul 13, 2006 | 02:20 PM
Posey204's Avatar
I feel ya Allshot
I know exactly what you are talking about with the rpms dropping. I got a 06 SS/SC with about 5k on it bone stock. Mine doesn't do it ever in reverse though. I have seen it doing it like when im pulling up to a stop sign/light and i have the clutch fully pressed just rolling going around 20 mph. The rpms drop way down (below 1000) 3 times then the car idles back up like nothing ever happend. Some might not even notice it if they don't pay attention. The only reason I notice it was bc i was watching how rpms seem to adjust themself to your speed when rolling with clutch fully depressed.
ColonelMustard
North Pacific
Sep 29, 2015 03:02 PM
Extremespeed
Sep 29, 2015 04:34 AM
jrocstar
Sep 26, 2015 11:42 PM
Coballin13
Sep 25, 2015 08:43 AM
