Cruse Control Problems
Old Nov 5, 2008 | 05:50 PM
KyFritz06SS's Avatar
Alright i got my SS/SC about 2 weeks ago and i noticed that my Cruse control does not like to engage. Now i dunno if thats how its supposed to work on our cars or what. I was on the Highway today and it decided to work for some reason at cruising speeds around 75. I tried to set it around 55 and 45 and what ever other speed you could think of and it wont work. If i hit it a few times the Cruse Engaged Flashes but it wont engage. Has anyone had this problem? or do i just need to take it in to the dealer. Thanks in advance.
Old Nov 5, 2008 | 05:56 PM
Black SS/SC 06's Avatar
I would take it in.
Old Nov 5, 2008 | 06:00 PM
BowTieTillIdie's Avatar
I don't even use cruise on a manual .. No point every one goes slower ..
Old Nov 5, 2008 | 06:03 PM
I use mine if I am traveling long distances.
Old Nov 5, 2008 | 06:08 PM
Feardavid0586's Avatar
i got my SS/SC about 6 months ago and my cruise went out not to long ago.....i havent had time to take it in but i feel your pain brother, and i have no clue how to fix it myself!
Old Nov 5, 2008 | 06:24 PM
Maven's Avatar
Its a very common issue. Before you go to dealer disconnect your battery and touch the two cables together for 15 seconds, reconnect battery, if its the normal Cobalt issue your cruise will work. If it still doesnt youll need service
Old Nov 6, 2008 | 02:39 PM
Cool thanks guys. Now what will touching the wires together do. I always thought that was a NO NO. But i could be wrong. I will try that tonight if that does not work im taking it in tom.
Old Nov 6, 2008 | 03:54 PM
Maven's Avatar
That complete the vehicle power circuit, and since theres no battery, all modules will completely power down.
Your not crossing or touch LIVE battery cable here.
DISCONNECT BOTH battery cables from the battery. Now touch both of the cables that were connected to the battery, to each other. No sparks, no drama. Factory recommended procedure for powering down all modules and reducing/eliminating "logic lock" that occurs in modules making them do weird/incorrect things
Old Nov 6, 2008 | 03:58 PM
06black's Avatar
clutch switch fault.
no bigge, a simple disconnect and a few moment of your time are all thats needed.
Old Nov 6, 2008 | 06:51 PM
DaBuzzard's Avatar
The GM version of "CTRL ALT DEL"
Old Nov 6, 2008 | 08:34 PM
Coulnt have summed it up any better ill remember this. Thanks everyone.
Old Nov 6, 2008 | 08:36 PM
LS6Rally's Avatar
mine went, and i got a code. i had to get a clutch switch
Old Nov 7, 2008 | 02:32 PM
toolman's Avatar
Same here. I didn't get a code for a while after the cruise stopped working, but it was the upper clutch switch. I could wiggle the clutch a bit and sometimes get the cruise to engage, but it was not very often. Also, you might notice the RPMs start hanging when you try to shift... at least my 2.4 did that, and it was all because of that little switch.
Old Nov 7, 2008 | 10:11 PM
LS6Rally's Avatar
yea same stuff i had. hanign R's and no cruise. it was code 14XX. i thiink
Old Nov 7, 2008 | 10:15 PM
mattcossel29's Avatar
I had the same issue.. It went away by letting it sit over night.. hasnt been back since..
ColonelMustard
North Pacific
Sep 29, 2015 03:02 PM
DocSvensk
Sep 27, 2015 02:24 PM
Adiaz1ss
Sep 26, 2015 11:51 PM
Coballin13
Sep 25, 2015 08:43 AM
