Delema
Old May 1, 2008 | 10:00 AM
nuttzzy's Avatar
Delema
The Delema Is.....
I seem to keep breaking things on my cobalt Clutchs, axels, ect....
i ordered some drag radials and upgradeing my axels.... my racing clutch didnt hold any long than a stock one for some reason
i heard with hpt you can dump the boost in first to lower your power for some reason s not breaking things lower torque so you cn hook up ect... but iff im getting radials should i lower boost in first also?? or will the radials take care of the traction problem and make more strain on the drivetrain???
any opinions apprectiated...EXCEPT....this one "Dont Race you wont break your car" i have heard that to much
Old May 1, 2008 | 10:06 AM
68nova200's Avatar
sounds like you are launching to hard. try launching at lower rpms
Old May 1, 2008 | 10:09 AM
SSRedSC's Avatar
Lowering your boost in first would still help reduce the stress on your drivetrain, but you got the axles now and thats what most seem to worry about breaking. You could still lower it a little but I would check your new times with the slicks first so if you do get it dropped down a little you know how you did in the first place.
Old May 1, 2008 | 11:15 AM
nuttzzy's Avatar
no its at gm getting stock axels i think.. soon as the dumb ass decide that the exploded cv joint isnt part of the clutch. the stage 2s is my next perchase now that i have everything else paid off.. i also own hpt so if i dont like the lower boost ill be able to raise it back again from what im told.
what rmp would you recomend??? this preticular time i had a stage 3 exedy clutch ..(not much room to slip or ease on the gas) .. and i launched about 2k rpms. however the track was prepare quite well no screech or anything just a leap forward a pop and that was all she wrote...when i got out to help push the car off the track, the track was so tacky it damn near pulled my shoe off.
Old May 1, 2008 | 08:43 PM
maverick0716's Avatar
Just for the record, an aftermarket clutch will put more strain on the transmission and axles, because it bites a hell of a lot harder than the stock clutch......and with very little room to slip as you mentioned. Putting drag radials and adding a Stage II kit is definitly going to make it worse. I don't think the stock axles are going to cut it, based on how you drive.
Old May 1, 2008 | 08:46 PM
68nova200's Avatar
the stock axles are not know for being strong. i would recommend better axles. as for launching you have to feel out the car and figure out what is best for the car.
Old May 1, 2008 | 10:53 PM
nuttzzy's Avatar
as i said earlier Stage 2 axels are next on the list as long as i dont punch it at a low speed i should be ok...correct? AKA drive normal till i get the axels on
rockstarbass1
Apr 29, 2010 10:03 PM
crossed over
Canadian Mid East
25
May 7, 2007 01:56 PM
crossed over
Sep 13, 2006 08:19 AM
