Dic problem
Old Oct 17, 2013 | 07:28 PM
2010CobaltLTfan's Avatar
Dic problem
At idle my dic will blink when the lights are on but when driving it stops can someone help
Old Oct 17, 2013 | 09:32 PM
05g5's Avatar
Loose wire? Like any 4 banger they shake at idle . Could be causing it to short/ground out? My best guess, id just look at wires
Old Oct 17, 2013 | 10:19 PM
Could it be a voltage problem I'm running a amp and sub
Old Oct 17, 2013 | 10:20 PM
Sounds like a personal problem
Old Oct 17, 2013 | 10:22 PM
Seriously
Come on it's not a personal problem
Last edited by 2010CobaltLTfan; Oct 17, 2013 at 10:22 PM. Reason: Automerged Doublepost
Old Oct 17, 2013 | 11:19 PM
TheDom's Avatar
Uhhh...............bahahahahahaha hahahahahahaha wooooooooooooooo hohohohohohoho
sorry but my inner 12 year old thought that was hilarious.
Old Oct 18, 2013 | 12:59 AM
Thanks for the help............
Old Oct 18, 2013 | 01:41 AM
buildmeanempire's Avatar
Not everyone can give you the answer you like. You're going to need to investigate and do some work on your end.
Old Oct 18, 2013 | 06:10 AM
GreenySC2's Avatar
do you have a capaciter somewhere in your system? if not you should... i do in my weak little saturn.. it helps with the harder beats it puts out...
dont know or think it'll help but its always worth a shot...
Old Oct 18, 2013 | 08:07 AM
05g5's Avatar
Take your deck out and inspect all the wires. If you tapped any together take it apart and redo. Twist tightly
Old Oct 18, 2013 | 08:10 AM
blueLNFftw's Avatar
Capaciter is a band aide.
I agree with this.
WebMD - Better information. Better health.
Last edited by blueLNFftw; Oct 18, 2013 at 08:10 AM. Reason: Automerged Doublepost
Old Oct 18, 2013 | 09:54 AM
Lame9910's Avatar
If your's shakes at idle I would look into it. Mine runs smooth as a whistle lol.
Old Oct 18, 2013 | 12:17 PM
05g5's Avatar
Not a shake rhat will spill coffee obviously. Just not as smooth as a v6 or 8 would be
Old Oct 18, 2013 | 12:31 PM
Xmetalhead2003X's Avatar
Motor and tran mounts? Could cause a vibe and make things loose.
Old Oct 18, 2013 | 12:52 PM
blueLNFftw's Avatar
Lol at your whole logic on this....
Old Oct 18, 2013 | 04:57 PM
GreenySC2's Avatar
cao might be a band-aid but dont lie, its always a good thing to add to an obviously under powered alternator....
common practice my man....
Old Oct 18, 2013 | 06:00 PM
I was told by many of people that caps are a waste of time and money I've had one and it didn't work to well in my other car but I think I fixed the problem
Old Oct 18, 2013 | 06:06 PM
No caps are not a waste of money, they help provide constant power to your amp, a cap can help with the hard hits, but if you drain it completely then its only a band aid. A bigger/higher out alternator would be the best with a correctly sized cap
Old Oct 18, 2013 | 06:18 PM
06cobaltncng's Avatar
I keep reading this as "dick problems" haha
Old Oct 18, 2013 | 06:49 PM
05g5's Avatar
.. it isnt rocket science, or new knowledge that straight 4, and even more so a cummins for example have a shake at idle. its just not a balanced as a V shape.
therefore it would not be uncommon for things to eventually wear, and cause a similar problem to what hes experiencing.
Old Oct 18, 2013 | 08:59 PM
Damn guys my car doesn't shake bad at idle that's fine I fixed the problem
Old Oct 19, 2013 | 01:19 PM
05g5's Avatar
What was it?
Old Oct 19, 2013 | 01:50 PM
The main ground wire for the car was loose
Old Oct 19, 2013 | 02:20 PM
05g5's Avatar
and doesnt that prove my point about straight 4/6 cyclinders?
anyways, glad its fixed. wish i could say the same about my shitbalt
Old Oct 19, 2013 | 02:28 PM
EmperorJJ1's Avatar
did u check voltage? does it stop with the lights off?
turbochargedss2012
Sep 20, 2023 12:17 PM
yellow dragon
Sep 28, 2015 09:49 PM
Iceberg
Sep 28, 2015 01:31 PM
DocSvensk
Sep 27, 2015 02:24 PM
Adiaz1ss
Sep 26, 2015 11:51 PM
